those of you with battery in trunk - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 07-14-2006, 10:10 PM Thread Starter
Windchime88's Avatar
i need opinions on how to mount the thing. car is a 93 coupe, i got the summit racing relocation kit, and got a dmaller box, since i dont need the huge one that comes with the kit. i've got a group 24 box, with the appropriate battery inside it, but i was wondering how everyone is fastening the whole assembly down. i've got the cross bar that goes over the bat., and the hook brackets that clip over it, but there's no way to fit the j-bolts between the bat. and the box. what do i do?
1985 Thunderchicken, 11:1 351w, t5, spooled 5.67 geared 9" sn95 brakes
2003 std cab f150, 351w and 3spd toploader, crown vic suspension, spooled 6.0 geared 9" roundy-rounder
Windchime88 is offline
post #2 of 7 Old 07-14-2006, 10:57 PM
Blue92LX's Avatar
get long threaded rod from home depot. You will have to drill through the trunk floor and fasten the rod under the car with a locking nut. You may have to lower the gas tank too.
01 Lightning
12.54 1.77 60 on F1's 427RWHP 533 TRQ
01 Mustang GT
13.8 stock
92 Lx 5.0
Underconstruction =)
DSS 306, AFR 185, FTI cam, custom turbo setup
95 Escort GT
[email protected] 300hp custom turbo
Blue92LX is offline
post #3 of 7 Old 07-14-2006, 11:25 PM
seeya's Avatar
got the same problem with the summit box. Looks like I'm going to have to get a custom box.
'11 V6 202A Cosmetics so far...hers.
'95 GTS this and that
'90 LX 401k, Roth IRA, Citi Bank, etc....
seeya is offline
post #4 of 7 Old 07-15-2006, 12:03 AM
Constable's Avatar
When I bought my car, the original owner had welded threaded rod to the trunk floor and they came up along the outside of the box. He ran the neg cable directly to one of the rods. It worked, but wasn't the best looking setup. I ditched it all and went with a Taylor box and drilled through the floor. Dropped the tank and bolted everything down snug near the cross brace that runs in front of the gas tank.
'01 Lightning #1910 [silver] - SOLD
'93 Notch [bright red] - SOLD
'95 Lightning #13 [black]- R.I.P.
'93 Notch [electric red] - SOLD
Constable is offline
post #5 of 7 Old 07-15-2006, 02:46 AM Thread Starter
summit doesnt exactly supply instructions with their crap. all i got was a template for the holes, but since im not using that 500sq. foot box they send, the template doesnt help me much.
the one thing i was thinking, was running the rod through the floor, as stated, and cutting a slot in the box for that little tab/hook thing to go through. then just run the j-bolt through that. only problem there is that once it's mounted, there's really no way to get the battery out. not without dropping the tank to get to the nuts again.
post #6 of 7 Old 07-15-2006, 04:39 AM
I hated to go under the car every time I need to remove a battery. So I welded 2 short square rails (perpendicular to the car axis) to the trunk floor (which required lowering fuel tank to protect it) and bolted my Summit box to those rails. This elevated the box by 1.5". Then I took 2 steel bars with holes on both ends, put one under the battery box, put another over the battery, ran threaded rods through them and through box floor and they work as clamp downs.
This may not be the most elegant solution, but it works very well.
Summit instructions made me laugh.
Karpusha is offline
post #7 of 7 Old 07-15-2006, 06:31 PM Thread Starter
no kidding.
"here's your battery box. it goes in the trunk. have fun!"
Critique this problem...battery in the trunk kbscobravert Electrical & Wiring 5 07-19-2015 09:52 AM
Wiring Check needed - Factory alternator wiring harness and battery cut of switch with trunk mount battery Adrenalin 94/95 Tech 0 06-01-2015 09:28 PM
trunk mount battery question... billison General Mustang Tech 7 10-26-2013 09:45 AM
Battery in the trunk problems my2000blowngt GT & SOHC 6 04-24-2013 11:58 AM
