Battery Relocation Info - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 07-04-2006, 10:48 AM Thread Starter
SVTCobraLTD's Avatar
I know lots of you guys have done this, but after doing a quick search, didnt find much on it. Someone have a write up on it already? Where did you run the wires, inside the car or outside? I would like to run it inside but was told it could interfere with the radio. Anyone have this problem? How did you run yours? What gauge wire did you use? Ive read to use 1/0 welding wire.
SVT
PennMustangs - Owner
PennMustangs.com
1993 Ford Mustang Cobra SVT
465rwhp/460rwtq on Mustang Dyno
SVTCobraLTD is offline
post #2 of 9 Old 07-04-2006, 11:42 AM
Many threads about this and yes the welding wire is great, it's easier to work into tight spaces, and more flexible than the alternatives. Do a "title only" search and just type in the word "battery"
5driver0 is offline
post #3 of 9 Old 07-04-2006, 01:39 PM Thread Starter
5driver0 did you run the wire on the inside of the car or the outside?
SVT
PennMustangs.com
post #4 of 9 Old 07-04-2006, 02:53 PM
slo88notch's Avatar
the wire on my car is on the inside, no radio problems. its only a 2ga kit, no charging/starting problems either.
1988 lx coupe R.I.P.
1986 lx coupe 11.46 @ 116.01 sold
1991 ssp coupe
slo88notch is offline
post #5 of 9 Old 07-04-2006, 03:37 PM Thread Starter
Now did you run one wire from the battery in the back to the starter solonoid? Or did you run two wires, one from alt to battery and one from battery to soloniod? No kill switch here.
SVT
PennMustangs.com
post #6 of 9 Old 07-04-2006, 04:04 PM
slo88notch's Avatar
no kill switch either. 2ga wire from alt solenoid. 2ga from solenoid to batt. 2 ga ground. thats how mine is wired, i didn't do it myself. but like i said no problems here.
1991 ssp coupe
post #7 of 9 Old 07-04-2006, 05:33 PM
hockeyguy713's Avatar
I am running the taylor aluminum battery box trunk relocation kit with the same wiring setup as slo88notch and I have no electrical problems. Plus the aluminum box looks sick back there.
-pete
91 GT
hockeyguy713 is offline
post #8 of 9 Old 07-06-2006, 01:24 PM Thread Starter
The wire from the alt to solenoid and from battery to solenoid connect to the same terminal on the solenoid correct?
SVT
PennMustangs.com
post #9 of 9 Old 07-06-2006, 02:17 PM
slo88notch's Avatar
SVT
yes.
1991 ssp coupe
