Battery Relocation With 3g Alt using powerwire - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 06-06-2006, 03:06 AM Thread Starter
nxstang's Avatar
Trader Feedback: (22)
Just Wondering Im in the process of Relocating my Battery to the Back and installing a Cut off switch I was told I have to remove my power wire that goes from the Back of my 3g to the starter relay for it to work is this True is there anyway around this so I can use the powere wire still?
02 Mustang Gt supercharged
11 F150 super crew Lariat
nxstang is offline
post #2 of 7 Old 06-06-2006, 02:07 PM
somersdp's Avatar
I had to run mine to the back of the car and to one side of the cut off switch..
SGT, US Army 1-101HHC
somersdp is offline
post #3 of 7 Old 06-07-2006, 03:58 AM
BLiND's Avatar
you dont remove it, you need to replace it with a longer one to go back to the cut off switch, it needs to be on the same terminal of the switch as the battery so that when you turn the switch off the car wont run on the alternator output and the car will shut off.
1989 Notchback LX H/C/I/5.0/T5/5 lug/10psi/Etc - ex 2.3L/A4LD
2002 F150 Harley-Davidson 5.4L/4R100 - Stiegemier Stage 4
BLiND is offline
post #4 of 7 Old 06-07-2006, 07:50 PM Thread Starter
nxstang's Avatar
Thanks man so insted of going from the cutoff switch to the back of the altenator I go from the cutoff switch to the starter Relay?
nxstang is offline
post #5 of 7 Old 06-07-2006, 08:09 PM
BLiND's Avatar
yeah, on the switch you'll have 3 wires.
2 wires on the left terminal, 1 from battery +, and one from the alternator.
the other terminal which is switched, goes to the starter relay so when you flip the switch off all power is cut.
BLiND is offline
post #6 of 7 Old 07-04-2006, 01:56 PM
SVTCobraLTD's Avatar
What about if you dont have a cutoff switch. Can you just leave the wire foing from the alt to the starter solonid?
SVT
PennMustangs - Owner
PennMustangs.com
1993 Ford Mustang Cobra SVT
465rwhp/460rwtq on Mustang Dyno
SVTCobraLTD is offline
post #7 of 7 Old 07-04-2006, 03:05 PM
slo88notch's Avatar
SVT
yes.
1988 lx coupe R.I.P.
1986 lx coupe 11.46 @ 116.01 sold
1991 ssp coupe
slo88notch is offline
