Ground cables for new carb motor? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 05-23-2006, 03:33 PM Thread Starter
I recently pulled my old EFI motor and installed a new carbed motor. The battery is still in the trunk as it has been for years. The battery negative cable goes to the quad shock bracket. That will be the same.
Right now I have a cable going from the block to the swaybar bracket in the engine bay. It is welding cable. The heads are aluminum and I do not have a ground attached to them (on the back of the head). Will I be O.K. with the one ground cable from the block to the swaybar bracket? I do not have a ground going from the firewall to the motor. Thanks.
bad89stang is offline
post #2 of 3 Old 05-23-2006, 11:14 PM
5SpeedGT's Avatar
You'll be fine. In fact, that welding cable ground in the engine bay is probably overkill.
'92 LX Coupe:T5 w/ Hurst shifter, '94 302, GT-40P's, Wolverine 1087 (Speedpro), Performer RPM Intake, Holley 670 SA carb, U/D's, BBK Lt's, BBK off road H, PYPES Pro-V cat-back, MSD 6AL, Pro Comp dizzy, Accel Coil, and pretty Blue Accel wires. Blue Oval Industries UCA/LCA's and Subframes.
5SpeedGT is offline
post #3 of 3 Old 05-23-2006, 11:26 PM Thread Starter
Thanks, it was leftover from the battery relocation
