need to find 12V switched power - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 04-12-2002, 01:02 PM Thread Starter
Can someone point me to a good place to pick up switched 12 volts on an '87 GT? Thanks!
cougar14 is offline
post #2 of 3 Old 04-12-2002, 01:57 PM
MFE
Super Moderator
MFE's Avatar
If you don't get a better answer than mine, start by examining the fuse panel and I think you'll find a source labeled for you to tap into and I *think* it'll be switched.
MFE is offline
post #3 of 3 Old 04-12-2002, 02:39 PM
What is the switched power for? If it's something in the engine compartment you can just put a ring term on the starter side of the starter solenoid mounted on the inner fender. If it's in the passanger compartment then you could look at the cig lighter, radio, rear defroster, cruise control in the column, power windows, etc, etc. Just get out a test light and start poking around or get a $12 Haynes manual with a wiring diagram in the back.
Carson
1990 GT
2010 Taurus SHO
PASSDU2 is offline
1995 alternator power wire ! where to find Nally427 5.0/5.8 Engine Tech 1 01-14-2016 12:12 AM
Take my 306 to the limit MH60SMECH 5.0/5.8 Engine Tech 64 07-25-2015 01:29 PM
Where can I find a KOER 12v source on Fox?? FiveLiterFox General Mustang Tech 5 05-20-2013 02:07 AM
Man facing jailtime for owing child support commits suicide on courthouse steps MurPHy4570 Politics 96 02-19-2012 01:24 PM
CANT FIND THE POWER! WHATS WRONG WITH THIS 96 GT? Torino390 GT & SOHC 21 12-02-2001 04:59 PM
