battery relocation - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 04-09-2002, 03:24 PM Thread Starter
battery relocation
is there a kit i can buy? ... where is the best place to get it? ... if not how do i do it? ... does this really make a difference in traction at all? ... thanx guys
nc95fiveoh is offline
post #2 of 9 Old 04-09-2002, 03:32 PM
Anaconda's Avatar
Re: battery relocation
I remember seeing a kit for $39, but I am not sure where I saw it. I just know it was 39 bucks. I would GUESS that it is available at summit.
But yeah, you can do it yourself with some welding cable.
Anaconda is offline
post #3 of 9 Old 04-09-2002, 06:16 PM
I recently moved my battery to the trunk..... the big difference that i have noticed since is when i slam the brakes the car does not want to try to pull itself to the right anymore.. like if it evened itself out.. it also helped in my cornering ability.. as far as traction, i can't tell ya, have only been to the track once in my life.... hope this helps bud!
Buggapimp5.0 is offline
post #4 of 9 Old 04-10-2002, 01:11 AM
You need either a sealed box, or a sealed battery (optima) if you plan on running at the track, along with a cut off switch.
fiveptO is offline
post #5 of 9 Old 04-10-2002, 06:03 AM
US Army Active Duty
SVTCobra347's Avatar
Trader Feedback: (34)
Summit sells two kits, one for about $50 and a sealed NHRA approved one for about $90. I believe that they both come complete with everything you need. I am installing the cheaper one with an Optima Red top next weekend so I'll let ya know how much work it is.
SVTCobra347 is offline
post #6 of 9 Old 04-10-2002, 11:16 AM
This only applies if you are running under 12 seconds i believe..
post #7 of 9 Old 04-10-2002, 12:36 PM
twofast's Avatar
no. if you're running a battery in the back, you must have a switch. it doesn't matter what times you're running.
68 coupe
351W PT-88 E-98
700hp/643tq [email protected]
radials/street driven
twofast is offline
post #8 of 9 Old 04-10-2002, 03:22 PM
I have my battery in the back and have been told at the track in Miami Fl that i CAN run like that, and i have run like that. I asked when it would be applicable that i need a kill switch they told me only if i am running faster than 12 or something i forgot.. maybe the rules differ in your area..???
post #9 of 9 Old 04-10-2002, 04:20 PM
94CobraPace's Avatar
If it is a NHRA track and follow those rules, if a battery is in the trunk, there has to have a external cut off swith. Some tracks will not enforce the rule on a test & tune night. The battery has to be vented to the outside and have a barrier between the trunk & interior of the car.
2010 Shelby GT500, Kona Blue W silver stripes.
2007 Shelby GT500, Vista Blue with Tungston gray stripes, 1 of 119, Wifes car...
94 Cobra Pace car Convertible # 591
2001 Cobra vert # 2001 SOLD
94CobraPace is offline
