Best battery relocation kit and directions for an EFI car NHRA Legal! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 12-13-2005, 10:31 PM Thread Starter
Looking for the most complete battery relocation kit to move the battery to the truck but also would like to have outside charging post, on/off switch and must be NHRA IHRA legal so that when in the off position the car will cut off and not run. Thanks for any links and information
2006-2007 FFW Street Stang Champion
Mark Anderson
91AODGT TT is offline
post #2 of 8 Old 12-14-2005, 11:20 AM
quick50stng's Avatar
Trader Feedback: (41)
Both the Moroso and Taylor remote battery kits are nice and have battery box venting to be legal.
87 Coupe work in progress.
quick50stng is offline
post #3 of 8 Old 12-14-2005, 11:23 AM
The cable they give you sucks though.. 4 gauge wire just don't cut it.
fastfed is offline
post #4 of 8 Old 12-14-2005, 12:01 PM
Doktor's Avatar
The last Moroso kit I bought had 00 gauge wire in it. I don't know about the Taylor kits.
Experience is the hardest teacher. It gives the test first, and the lesson afterwards
To upset a Conservative, lie to them. To upset a Liberal, tell them the truth.
Doktor is offline
post #5 of 8 Old 12-14-2005, 12:45 PM
Mark Harrell's Avatar
Pardon my ignorance… but why/what’s the purpose of an external cut-off switch?
'86 GT : Original Owner, Speed-Density 331
'86 GT Convertible : Mostly Stock 5-speed
'67 Convertible : 289 Resto-mod
'74 F100 : 240 I6
Mark Harrell is offline
post #6 of 8 Old 12-14-2005, 02:13 PM
Because a fuel injected car can still run upside down... A fuel pump can still run upside down or on its side.
Pretty much if **** happens and gas is getting pumped out of the tank to a place you don't want it to go then you would want a person on the outside to have the ability to turn it off short of climbing into the car.
silentst2000 is offline
post #7 of 8 Old 12-14-2005, 02:49 PM
It might be best to find a suitable battery box by itself and use welding cable for the cables because it is a heavier gauge and it has more strands in the wire making it easier to bend than the cable included in most kits.
I have never seen a kit that includes every thing including the master disconnect switch. Those are sold individually.
post #8 of 8 Old 12-14-2005, 05:34 PM Thread Starter
The main reasons are for safty. If you get in a wreck the first thing they want to do is disconnect the battery. Less of a chance a short could cause a fire. Also if you are at the starting line and something is leaking like gas, or oil they can cut your car off at the line.
Mark Anderson
