Fan stopped working...things to check? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 04-05-2002, 01:50 PM Thread Starter
I haven't even popped the hood yet (gets hot at a stop, cools off when I start moving, 99% sure its the fan tstat and radiator are new), just checking if there is anything anyone would recommend checking so that I may be able to fix it faster.
Jon 94GT is offline
post #2 of 7 Old 04-05-2002, 03:17 PM
Your coolant temp sensor is probably bad. Itis a brass sensor screwed into the top of the upper intake manifold and is an easy repair
Terry Patton
Sold this one now... 95 5 speed 'vert...now with Fluidyne radiator, Pullies, 65mm TB, Bullet 75MAF, WMS Cold Air Induction w/ K&N, PBR 2 piston caliper brake upgrade.
THE 94 HAS BEEN TOTALED 3/19/02...LONG LIVE THE 95!!!
Used to have a:
94gt Convertible w/AODE (OINK!)
JMS Chip, Romac Balancer, Art Carr modified valve body and some internal upgrades, Borla cat-back, FMS 3.73 gears, FMS "B" springs & Tokico non-adjustables, Hotchkis CC plates
In my garage waitin' for heads...Cobra intake, 1.7RR's
TJ 94gt vert is offline
post #3 of 7 Old 04-05-2002, 03:20 PM Thread Starter
Why would the temp sensor show a different reading at a stop than moving?
I am almost positive the temp sensor is not the problem...
Jon 94GT is offline
post #4 of 7 Old 04-05-2002, 03:23 PM
Banned
There's a recall on the 95's I don't know if any 94's are included. See if you can turn the fan by hand. The bearings go bad and cause the wiring harness to melt.
post #5 of 7 Old 04-05-2002, 03:33 PM
Don 95Vert's Avatar
See my reply in the other forum.
The ECT going bad is very common on SN-95's. It gets hot when you stop, because no air is moving through the radiator. The air is moving when you are moving. If you have a working fan, when you stop, air will still move....
95 Lightning - Slow
95 Convertible 357 turbo
10.5/135 @ 3800#
SCT Tuned
Don 95Vert is offline
post #6 of 7 Old 04-05-2002, 03:44 PM
trust me...this is most likely the problem. It is a commom problem and easy/cheap to fix. The recall does not include the '94. Only '95
Terry Patton
Used to have a:
post #7 of 7 Old 04-05-2002, 03:54 PM Thread Starter
Thanks for the replies...I will try the things you suggested...I see what you are saying about the ECT now. Thanks again...
Jon 94GT is offline
