Battery relocation - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 11-03-2005, 12:41 PM Thread Starter
Formerly known as jbj302
NotoriousNotch's Avatar
Trader Feedback: (51)
Question Battery relocation
I'm in the process of relocating my battery to the trunk. Is there anything special I need to do while I'm installing the kit? Any problems that I may run into and should avoid? Just anything that will make this installation as simple as possible. Thanks in advance
NotoriousNotch is offline
post #2 of 7 Old 11-03-2005, 01:02 PM
Use 1/0(0/1 can't remember which way) welding wire. Much more flexible.
FORCED87GT is offline
post #3 of 7 Old 11-03-2005, 10:39 PM
buck87's Avatar
I'm in the process of doing that myself. I just need to get some wire. Are you using a regular battery? They said I have to seal my marine battery box and make a vent tube to exit out of the car. Firehazard or something? I haven't heard of anyone using a fuse in between the battery and solenoid. This seem like a bad idea to me and i'm looking to install one just to be on the safe side. (S**T happens)
buck87 is offline
post #4 of 7 Old 11-03-2005, 10:41 PM
buck87's Avatar
what kind of coating does welding wire have on it? Like audio cable wire?
buck87 is offline
post #5 of 7 Old 11-04-2005, 02:16 PM
marius's Avatar
Heavy industrial rubber...it will take a beating and not wear down...the copper also has a paper type element wrapped around it before the rubber outer is applied...well worth the effort to use...IMHO
https://www.corral.net/forums/showthr...ery+relocation
diagram for routing with or without cutoff switch
http://fordfuelinjection.com/index.php?p=8
General wire gauge for your car
Battery box needs to be vented because of fumes and vapors it releases....i think NHRA requires it if you go to the track? someone will chime in for that answer...if you buy a high end sealed battery you may not need to vent...just 2 cents.... good luck
86 gt many mods
07 R1 a few mods
02 Z71 tahoe no mods
marius is offline
post #6 of 7 Old 11-04-2005, 02:53 PM Thread Starter
I'm using a Optimum Red Top Battery. I ordered a Taylor kit from Summit. I just need somewhere to place my Snow Boost Cooler.See link below.
http://store.summitracing.com/defaul...=egnsearch.asp
post #7 of 7 Old 11-05-2005, 12:50 AM
YBUYGM's Avatar
Last time i asked the NHRA tech they said the box had to be vented no matter what type of battery. they explained it as easier to control one set of rules. This mayhave changed it was couple years ago I asked
Never knock on death's door. Ring the bell and run.
Death hates that.
1990 Mustang Gt
YBUYGM is offline
99-04 Mustang GT Battery Relocation surtofak Electrical & Wiring 3 10-12-2015 10:43 AM
NHRA and battery relocation TomR Drag Racing 2 08-15-2013 06:20 AM
Battery kill switch/no battery relocation 97stanger97 GT & SOHC 11 06-10-2013 09:23 PM
For Sale NIB UPR Battery relocation kit, Complete** marlboroman8792 Electronics and Entertainment 6 11-05-2011 09:36 PM
