Fuel Pump Relay - Where is it? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 03-24-2002, 12:11 PM Thread Starter
Anyone know where the fuel pump relay is? In the Underhood-Fuse Box or else where? There is a Resistor? and where is the fuse?
Autofantasy is offline
post #2 of 3 Old 03-24-2002, 02:42 PM
Anaconda's Avatar
Do you mean the connector back by the driver's side taillight? You have to move that trunk lining out of the way to get it. Granted, I am not sure if that is what you are talking about or not.
Anaconda is offline
post #3 of 3 Old 03-24-2002, 10:06 PM
The fuel pump relay is in the ccrm (constant control relay module). If it is bad, you have to replace the whole unit.... you can't just replace the fuel pump relay. The ccrm is behind the coolant bottle, it is a black box that has a big wire harness connector on attached to it.
Are you having a problem?
Later,
Bill
Nitro_Snake is offline
