Color of wire for dimmer / light on mechanical fuel gauge - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 03-23-2002, 05:30 PM Thread Starter
86style's Avatar
someone know the color of the wire i need to connect to that will give me light and dimmer function on my mech, fuel pressure gauge???
the black wire is for ground...where does the white wire connect?
i just need the color of the wire and the easiest place to locate???
thanks
04 Torch Red Cobra Whipple @ 16psi
JDM tuned 587 h.p. / 520 lb/ft
86style is offline
post #2 of 3 Old 03-24-2002, 12:21 PM
It always used to be light-blue with a white stripe... Your stereo harness should have one you could use... or use the ones from the HVAC controls?
Autofantasy is offline
post #3 of 3 Old 03-24-2002, 10:59 PM Thread Starter
86style's Avatar
thanks for the tip. i was able to use the light/dimmer wire that runs to the radio. it worked great, ill post pics this week.
thanks again
86style is offline
flux welder on engine bay? 95oldyeller The Body Shop 9 10-17-2012 07:35 AM
Gas Gauge HELPP! outlawmustanglx General Mustang Tech 17 05-09-2012 06:12 AM
Want To Buy Mechanical fuel pressure gauge 93BLKNotch Electronics and Entertainment 1 02-21-2011 09:38 AM
