shift light problems - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-21-2002, 07:06 PM Thread Starter
i installed an autometer pro lite in my car about 3 days ago. the only pill i had was the 3000 test pill. it worked perfectly and came on at 3000. i got the correct ones today and put the 5200 in and now it won't come on. i put the 3000 back in, it works fine. on the plug going into the coil, there were 2 red wires going into the same terminal and 1 brown one. i hooked into one of the red ones. is that the right wire? what could it be? thanks
94 GT TFS Track Heat Intake, Twisted Wedge Heads, FTI Cam, 65mm TB, C&L 73mm MAF, 24# Injectors, Kirban AFPR, 255lph, BBK Longtubes, Off Road H-Pipe, BBK Underdrive Pulleys, Mac CAI, Pro 5.0 Shifter w/ tri-ax handle, Eibach springs, 3:73's, SPEC Clutch, JMS Chip. KB Subframe Connectors.
Best [email protected] 320rwhp 320rwtq
white94 is offline
post #2 of 4 Old 03-21-2002, 07:17 PM
PMS Tuning Forum Moderator
Redsnk95's Avatar
I just pulled out the whole terminal and pushed it back in with the green wire (from the shiftlite). Have you tried any other pills besides that 5200 pill?
Troy
1995 Mustang Cobra
347ci 10.52 @ 127.74 NA-Pump Gas (gone)
New Project in the works.
2009 F150 Lariat *tow truck*
Redsnk95 is offline
post #3 of 4 Old 03-21-2002, 07:54 PM Thread Starter
yeah, i tried a 5400 pill as well. still no luck.
white94 is offline
post #4 of 4 Old 03-21-2002, 11:57 PM
imflyinbiya's Avatar
try the brown wire. thats the one that i was told to use at it works great.
03 Cobra Convertible
www.vanquish-tech.com
imflyinbiya is offline
