Fox harness in sn95, how to wire up speedo/tach ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 03-19-2002, 01:45 AM Thread Starter
Has anyone swapped their engine harness with one from a foxbody ? How did you get the speedo and tach to work ? Is this possible ? since the fox cars had a cable speedo im not really sure how this would work, can you wire from the vss sensor to the speedo ? Will this work ? If anyone has any ideas Please let me know
THANKS
95 GT converted to Cobra Clone
Edelbrock upper and lower intake, 70mm TB, Pro M 75mm MAF, AFR 165cc heads w/ o-rings, Cobra 1.7 roller rockers, MAC Cold air intake, FMS 24lb injectors, MSD 6A ignition, accel coil, TwEECer MAC longtube headers, Off road X-pipe, mac catback exhaust, 3.73s, FMS frame stiffeners, trackit plus suspension kit-panhard bar, strut tower brace, 17" cobra Rs, FMS aluminum driveshaft with driveshaft loop
GreggN3 is offline
