anyone know where to hook up a shift light at? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 03-17-2002, 08:24 PM Thread Starter
i bought an autometer pro lite today. it has a positive, ground and tach output wire. is the tach output just the negative terminal on the coil? where should i run the tach output wire? thanks
94 GT TFS Track Heat Intake, Twisted Wedge Heads, FTI Cam, 65mm TB, C&L 73mm MAF, 24# Injectors, Kirban AFPR, 255lph, BBK Longtubes, Off Road H-Pipe, BBK Underdrive Pulleys, Mac CAI, Pro 5.0 Shifter w/ tri-ax handle, Eibach springs, 3:73's, SPEC Clutch, JMS Chip. KB Subframe Connectors.
Best [email protected] 320rwhp 320rwtq
white94 is offline
post #2 of 9 Old 03-17-2002, 08:25 PM Thread Starter
oh yeah, anyone have any good pictures or cool ideas where to mount one of these lights?
white94 is offline
post #3 of 9 Old 03-17-2002, 10:17 PM
Ih8losin's Avatar
Lightbulb Shift light idea
The green wire needs to go to the negative side of the coil.
I don't have any pictures at this time, but I mounted my shift light on the top of the clock housing.
Hope this helps!
Ih8losin is offline
post #4 of 9 Old 03-18-2002, 01:21 AM
BenW's Avatar
ack on top of the clock housing? That must almost touch the rearview mirror
I am mounting mine inside the air vent, so nobody can see it. I don't like gaudy stuff like that in the interior (also theft magnet). I don't have AC so the condensation issue is not pertinent. ANother good spot I have seen is on the steering column.
Ben
BenW is offline
post #5 of 9 Old 03-18-2002, 02:20 AM
StarrMan's Avatar
Got my tach (with built in shift light) mounted on top the steering column right in front of the stock tach. You really can't see it from outside (it's black and matches the dash) unless you really look.
In Loving Memory, My Son, Anthony Michael Starr 08/14/2007 - 01/21/2008
- 95 GT - Aluminum Heads, Cam, TMoss Cobra intake, S-trim, SCT BA2400, 55's, Longtubes, McLeod bell, TKO-600, 3.55's, etc
- 02 GT (Wife's Toy) - Auto, 4.10's, Lowered, Off Road X, Predator Tuner - [email protected]
StarrMan is offline
post #6 of 9 Old 03-19-2002, 12:38 AM
I mounted my shift lite upside down on the A Pillar right above the defrost vent for the driver side window. it almost gets overlooked by people checking out my car because of this location but you can't miss the flash it gives when racing. I have a pic I can email for someone to host if needed.
Paul
showstopper2 is offline
post #7 of 9 Old 03-19-2002, 11:20 AM
PMS Tuning Forum Moderator
Redsnk95's Avatar
I have my shift-lite mounted on my steering column. I didn't feel the need for a tach. I just my stock tach for staging purposes and just wait for the light to come on 3 times. Yes the green wire goes to the negative side of the coil or to the ignition box (if you have an aftermarket ignition box). I have a pic of the shift-lite on the steering column. Email me and I will send them to you. I can see all of my tach.
Troy
Troy
1995 Mustang Cobra
347ci 10.52 @ 127.74 NA-Pump Gas (gone)
New Project in the works.
2009 F150 Lariat *tow truck*
Redsnk95 is offline
post #8 of 9 Old 03-19-2002, 12:58 PM
slo94's Avatar
shift light
I'm with BenW!!!
Mount it inside the AC vent! I did that in a coupe I used to own and it was too kewl!
I think your problem is low self-esteem, very common among losers!
slo94 is offline
post #9 of 9 Old 03-19-2002, 09:11 PM
BenW's Avatar
Preach it!
BenW is offline
