No Blink 'n Fog - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-13-2002, 04:15 PM Thread Starter
No Blink 'n Fog
Got a 95 GT (See sig)
Prob #1: Turn signals.
The right turn signal works just fine when you hold it in the "Lane Change" position, so I kow the wiring and bulbs are Ok; But when I lock it on I get rear light only in that fast flash that usually tells you you got a bulb burned out.
I suspect I have a dirty contacts problem in the switch itself. Anyone know the way (non-destructive, of course) in there to see if that's true? (And mebbe spritz a li'l contact cleaner on the works?
Prob. #2: Fog Lites.
Right fog light went south. Took the bulb number supplied in the owner's manual to Kragen. Didn't get me anything but a 1000-mile stare from the kid there.
Anybody got a "Real P/N" for those bulbs handy?
fredkc is offline
post #2 of 4 Old 03-14-2002, 10:06 AM
#1) this might definitly be a bad bulb. I would go grab one from the parts store, and just swap it for the front and/or back and the problem should clear up. The bulb can still work, AND be bad at the same time. I Had that happen to a car I once owned. Same thing.. fast blink, but the bulb was still working. Swapped out the rear right bulb for a new one.. and vuala...
#2) I actually just bought one last week, still havn't put it in yet, I Have the package sitting on a shelf in my garage. When I get home... ill check it out and post the PN
BigPimpHustler is offline
post #3 of 4 Old 03-14-2002, 10:11 AM
Re: No Blink 'n Fog
I usually buy a 893 fog light bulb.
mgranzow is offline
post #4 of 4 Old 03-14-2002, 10:48 AM
erik_94COBRA's Avatar
I buy all of my bulbs at Wal-mart. They should have all of them.
If your problem turns out not to be a bulb, check the two grounds that are near the battery. I was having some problems with the way my indicators worked and one of the grounds (there are two, bolted to the core support) was undone.
Erik
'94 Cobra #2182
erik_94COBRA is offline
