Fuse/Circuit Breaker for Battery Relocation - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 11-25-2004, 09:37 PM Thread Starter
Question Fuse/Circuit Breaker for Battery Relocation
Finishing up with my battery relocation and came up with a question. I am using a 120a circuit breaker for the power wire off the alternator. I went to the local car audio store for a junction block to connect the alternator wire(stock alternator), basicly wanted the junction block for a cleaner install instead of splicing the wires together. The guy at the store mentioned I should use a fuse along with the circuit breaker. I dont really see the purpose of doing this. He said i should put the breaker right off the alternator and the fuse close to the battery. Any body have any thoughts on this??? Suggestions??? I am a dumbA$$ when it comes to anything electrical.
NVR ENUFF is offline
post #2 of 2 Old 11-25-2004, 09:46 PM
no fuses or circuit breakers in battery-to-positive side of solenoid.. they dont make a fuse big enough. get a master diconnect switch kit. this at least gives you time to get out and shut the power off in case you see a forrest fire coming.
1988 Hatch: 414w, AFR 225's, CompCams XFI 236hr cam, 42lb injectors, 95mm PMAS MAF, Reichard Racing Trick Flow TFS-R air gapped lower, TFS-R 90mm upper, Accufab 90mm tb, Kooks 1-7/8'' longtubes, Tremec 3550 TKO, 3.73's, Moates Quarterhorse, BE/EA
PoweredByAFR185 is offline
