Battery relocation tips/ideas - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 10-25-2004, 06:38 PM Thread Starter
Trader Feedback: (67)
Looking for some input on the subject. Some make there own kits, some buy kits, and some say the kits suck. Let me here the scoop. Im about to relocate mine. Shut off switch?
Need all info possible.
92 Coupe 408 and loving it!!
93 Coupe-RIP
90 Vert.Jan 05 MM&FF Cover Car SOLD
F/S:MIRROR POLISHED FIREWALL PLATES 79-93
tstang90 is offline
post #2 of 7 Old 10-26-2004, 06:54 AM
Here's one way: Battery Relocation
Try a search (if that feature is working). There should be lots of threads for that here.
Mike
'00 Mustang GT Vert: Long gone.
'83 Mustang GLX: T-tops,EFI 5.0L/T-5/8.8 transplant,Ebrock heads/int,F303,15psi Turbo,TwEECer R/T,3.27s,Cobra brakes...
Y2KStangGT is offline
post #3 of 7 Old 10-26-2004, 07:40 AM
That's a great thread
But another great tip(it might be in the thread)
Use 0 gauge welding wire. It bends allot easier.
FORCED87GT is offline
post #4 of 7 Old 10-26-2004, 08:06 AM
Kits suck!!! Make your own. Buy a good box, use welding cable from your local welding supply store, use marine type connectors.
Good grounding is the key. Make sure everything is grounded, block to frame, block to body, negative post to frame/block.
You need a cut-off switch if you are going to race NMRA.
88troopercoupe is offline
post #5 of 7 Old 10-26-2004, 12:13 PM
J's 89's Avatar
http://www.madelectrical.com/
Call this guy, and tell him to put together a kit for you. One thing I would suggest is mounting the battery box with spring nuts and threaded rod, like the ones that they use for the front fenders (except larger, I used 3/8ths). That way if you need to remove it for any reason you don't have to drop the gas tank to remove it. If you put it right over the rear axle and the battery dies there is not enough room to take it out without taking the box loose.
Jezekiah
Originally Posted by MegaGlide View Post
The arrogance on knife forums is completely out of proportion to those people's place in the food chain...
J's 89 is offline
post #6 of 7 Old 10-26-2004, 01:53 PM
dizntz's Avatar
nutz... j's 89 beat me to the punch... i second his opinion.. definetly check out www.madelectrical.com and call up with any questions or concearns.. the owner marc almost always answers the phones and is super friendly and helpful... plus all the products he sells, especially the 1/0 gauge wire is PREMIUM...
daily driver - '03 WJ w/2" lift
projects - '95 Lightning, '89 coupe, '80 GSX1100
backup - '97 Mountaineer
dizntz is offline
post #7 of 7 Old 10-26-2004, 04:26 PM Thread Starter
thanks guys
93 Coupe-RIP
tstang90 is offline
