BATTERY RELOCATION - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 10-14-2004, 04:31 PM Thread Starter
bill k's Avatar
Question BATTERY RELOCATION
I AM IN THE PROCESS OF HIDING ALL UNDER-HOOD WIRING. I AM RELOCATING THE BATTERY TO MY HATCH. I AM MOUNTING THE RELAY THAT THE POSITIVE SIDE OF THE BATTERY CABLE CONNECTS TO UNDER THE DRIVER'S SIDE FENDER. I PLAN ON RUNNING THE + CABLE BACK THROUGH THE CAR TO THE BATTERY MOUNTED IN THE HATCH. THEN I WILL GROUND THE NEG SIDE TO THE FRAME IN THE BACK END OF THE CAR AND GROUND THE MOTOR TO THE FRAME. DOES THIS SOUND RIGHT? ALSO, WHAT GAUGE WELDERS WIRE DO I USE? FROM NAPA??? THANKS
bill k is offline
post #2 of 11 Old 10-14-2004, 04:50 PM
Trader Feedback: (48)
Yes & O...
midnightrider is offline
post #3 of 11 Old 10-14-2004, 04:53 PM
sounds great and midnight is right O gauge wire
SMALLSTANG393 is offline
post #4 of 11 Old 10-15-2004, 11:01 AM Thread Starter
bill k's Avatar
thanks
bill k is offline
post #5 of 11 Old 10-15-2004, 11:24 AM
I would bring a negative cable back up to the motor.
You don't have too, but I read somewhere people having problem's with starting.
I ran two 0 gauge welding wire from front to back. Grounded to the frame in the back, front, and motor. No problem's so far. 3 Years and running.
IMO
FORCED87GT is offline
post #6 of 11 Old 10-15-2004, 11:34 AM
PURESTREET5006's Avatar
I have mine grounded to the block with 2GA wire...It has no starting issue's what's so ever even with 11:7.1 comp.
" In trouble as always"
Need a Roll bar or custom Cage?
Darrin Carter...C&C Motorsports..chicago/michigan.
NMRA P/S 5006
With Help From:
FTI
HarlandSharp
Whites pit's stop.
CenterForce Clutches.
JPC Racing.
AXLES ETC..Lansing, Ill
Moving Solutions..Belmont Mi.
SuttonHP..Matteson,Ill
Liss CarStar collision Center..crown point Ind.
PakMan MotorSports Inc, LockPort, Ill
Pro-Systems Carburetors..Spring Lake, Mi
Denso Iridium spark plugs.
PURESTREET5006 is offline
post #7 of 11 Old 10-15-2004, 12:13 PM
Thumbs up Negative all the way to the engine
I am one of the many who have had trouble with this. The car starts fine at home, head down the road, make a quick stop, come back out and she wont start. It has something to do with the engine being warm I guess. Anyway, I had + from batt to relay in front and - from batt to frame. I had problems all the time. I added another wire and ran the - from the batt all the way to the factory location on the engine block and no problems since. I also have a ground strap from block to frame. Good grounding is the key. Good luck.
88troopercoupe is offline
post #8 of 11 Old 10-15-2004, 07:37 PM
buffhomer's Avatar
Just do it like this:
http://buffhomer.corral.net/custom.html
Simply remove the cutoff switch from the diagram if you're not gonna put one. I've got hundreds of happy enthusaists using this setup.
buffhomer is offline
post #9 of 11 Old 10-15-2004, 10:35 PM
marius's Avatar
i ran double 0 for positive and batt negative. and 2 for the ground from motor to frame. ive never had the slightest hint of a starting problem, even with the electric fan on when starting. and i do alot of stop, starting driving in houston.
86 gt many mods
07 R1 a few mods
02 Z71 tahoe no mods
marius is offline
post #10 of 11 Old 10-16-2004, 01:11 AM
bob4499's Avatar
yes i used this setup on mine with no hot start problems make sure you use the welding wire not that cheasy **** that comes with the relocation kits
95 Mustang Gt 302 Anderson B-31 cam,Twisted Wedge heads, 1.6 RR , TFS Street Heat intake, 42 Lbs. injectors, 75 mm TB, 80 mm Mass Air, MSD 6AL, MSD coil, AFM PMS(tuning), MAC 1 3/4 Long Tubes, X-Pipe, Vortec S Trim @ 15-17 Psi, AFM Power Pipe, C-4 Trans, 3200-3500 Stall, 4.10 Gears, QA1 K-memeber, QA1 control arms, UPR coil over kit, UPR caster camber plates
bob4499 is offline
post #11 of 11 Old 10-16-2004, 02:05 AM
MAT88GT's Avatar
lol...I had zero starting problems with 4ga cable so long as my riding lawn mower battery was fully charged
1 x 4ga ground from battery to rear subframe rail
2 x 4ga grounds from each forward subframe rail to the block/head
MAT88GT is offline
99-04 Mustang GT Battery Relocation surtofak Electrical & Wiring 3 10-12-2015 10:43 AM
NHRA and battery relocation TomR Drag Racing 2 08-15-2013 06:20 AM
Battery kill switch/no battery relocation 97stanger97 GT & SOHC 11 06-10-2013 09:23 PM
For Sale NIB UPR Battery relocation kit, Complete** marlboroman8792 Electronics and Entertainment 6 11-05-2011 09:36 PM
