windshield wipers and fan will not go off - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 03-05-2002, 04:10 PM Thread Starter
ok when the battery is hooked up the fan automatically comes on... when i turn the key half a turn the windshield wipers come on, the switch is set to off too..
this all started to happen when i put a new alternator in my car
can anyone help me?
i have no idea what the hell happened
jordanpace is offline
post #2 of 2 Old 03-05-2002, 09:11 PM
If I am reading the EVTM correctly, the fan and the wiper control module share circuit 57 to ground splicing in both at splice s100 but with the wiper control module grounding at g204 and the fan grounding at ground g103. g103 is is located at the right front of the engine compartment. g204 is behind the dash in the center.
This is the only thing that I see that they share. This really does not sound like a ground problem though. have you tried to disconnect the battery for about a half hour and then try again?
I wish I had the shop manual to go along with the EVTM. It would probably help alot.
streetsnake94 is offline
