Is 2 gauge wire ok for trunk mounted battery? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 07-13-2004, 06:38 AM Thread Starter
Erich's Avatar
I want to make some room under the hood of the notch. Summit has this battery move kit for pretty cheap- like 45 bucks but it runs 20 feet of 2 gauge cable. The better kits seem to use 1 gauge. Will 2 gauge do the trick? The car does not have many electrical accessories: AC delete, stock radio, no fogs etc.
Also, the wire should run inside the car, correct?
Erich
Erich is offline
post #2 of 5 Old 07-13-2004, 08:29 AM
bob4499's Avatar
I used 1/0 welding cable for battery relocation and it works great (no slow cranking problems or hot start problems like some of my friends), used a 2 gauge welding cable for running the alternator wire to the back
95 Mustang Gt 302 Anderson B-31 cam,Twisted Wedge heads, 1.6 RR , TFS Street Heat intake, 42 Lbs. injectors, 75 mm TB, 80 mm Mass Air, MSD 6AL, MSD coil, AFM PMS(tuning), MAC 1 3/4 Long Tubes, X-Pipe, Vortec S Trim @ 15-17 Psi, AFM Power Pipe, C-4 Trans, 3200-3500 Stall, 4.10 Gears, QA1 K-memeber, QA1 control arms, UPR coil over kit, UPR caster camber plates
bob4499 is offline
post #3 of 5 Old 07-13-2004, 11:02 AM Thread Starter
Erich's Avatar
Hmmm. Good idea using welding cable. Do you need to run the alternator to the back?
Erich
Erich is offline
post #4 of 5 Old 07-13-2004, 06:06 PM
Timmy2734's Avatar
my 2 guage works fine. You only need to run the alternator to the trunk if you want be NHRA legal, with a rear mounted kill switch.
Timmy2734 is offline
post #5 of 5 Old 07-13-2004, 06:19 PM Thread Starter
Erich's Avatar
If 2 gauge works fine, I'll just get that summit setup and be done with it.
Erich
Erich is offline
