Battery Relocation + 3G Alternator - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 06-12-2004, 03:39 PM Thread Starter
I'm going to be doing the battery relocation from Buff Homer's Site. The Question I have is I will not be running a cut off switch, so should I run the 2G wire from the alternator all the way to the back to the +on the battery or just run it to the + on the Starter Solinoid under the hood. Running to the starter Solinoid would use much less wiring. Also I was gonna run a 150 amp slow burn fuse. Does this sound right. Thanks.
Slasher99 is offline
post #2 of 4 Old 06-12-2004, 04:15 PM
u still need a long wire to go to the pos batt. the wire from the alt to solenoid is for "protection" if i'm not mistaken. the factory wires are too small for that alt.
87blustang is offline
post #3 of 4 Old 06-12-2004, 05:24 PM Thread Starter
K, I have 1/0 wire going from the solinoid to the +pos on the battery already. On buff homers site he has a 1/0 cable from starter solinoid to the + on the battery in the trunk. He also has a 2G wire running from the alternator to the Kill switch in the back. Since I'm not running the kill switch in the back there is no need to run the 2G wire from alternator all the way to the back!! right. I should be able to just run the 2G wire from 3G alternator to the starter solinoid.
THis is the link..... http://buffhomer.corral.net/custom.html
post #4 of 4 Old 06-12-2004, 06:45 PM
Timmy2734's Avatar
Yes, just go to the solenoid.
Timmy2734 is offline
GT500 Alternator Bracket / Oil cooler delete / relocation Mod Mustang Racing Modular Mustang Racing 0 11-04-2016 05:39 PM
99-04 Mustang GT Battery Relocation surtofak Electrical & Wiring 3 10-12-2015 10:43 AM
Battery kill switch/no battery relocation 97stanger97 GT & SOHC 11 06-10-2013 09:23 PM
Battery Relocation Wiring help... danielhv Electrical & Wiring 3 03-30-2013 09:45 PM
1994 Battery relocation - Positive cable to power box fiveptO Electrical & Wiring 1 01-02-2003 08:12 PM
