ROUTING OF BATTERY CABLE? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-22-2004, 05:32 PM Thread Starter
Lightbulb ROUTING OF BATTERY CABLE?
Has anyone run their Battery cable through the inside of their car when doing a battery relocation? I'd like to hide the cable under the carpet but I'm not sure if there is any place on the lower part of the firewall that I can run the cable through? Any insight on this would be terrific!
1991CALYPSO is offline
post #2 of 5 Old 05-22-2004, 05:39 PM
Run it through the rear side by the shock tower, under the sill plate and drill a hole for a grommet under the factory computer harness. Run it behind the right kick panel.
Remount the soleniod to right strut tower on back side.
andr50 is offline
post #3 of 5 Old 05-22-2004, 06:42 PM
Mavrick's Avatar
In my case, i removed the cruise control crap, and that left a hole with grommet in the firewall, beneath the fender. I used this hole and it works great.
1988 Coupe 5spd
Windsor JR's, XE264HR-14, Cobra intake, BBK long tubes, frame connectors, 4.10's, 03 Cobra brakes and wheels, FMS B springs
Mavrick is offline
post #4 of 5 Old 05-22-2004, 08:58 PM Thread Starter
Thanks for the options guys, keep em coming
post #5 of 5 Old 05-22-2004, 09:58 PM
Do it like Andr50 says to, except get your self an 'insulated pass-through' from Long acre. Is basicaly an insulated puck with a stud on each side. Much better then a gromet. Get two, one for the altenator-to kill switch, and one for the battery + to solenoid.
RI lx is offline
