battery relocation - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 05-01-2004, 07:18 PM Thread Starter
battery relocation
battery relocation
I was thinkin bout makin my own battery box..Is there anything i should watch out for while makin it considering i will need to pass tech b/c ill be runnin true street and things like that when they come near town. Also can i just put this above the carpet? I was thinkin about getting some alumin steel and just fabing it in a box with a top then have a latch on it and ordering the relocation kit from jegs that include the wires.
2006 F-150 King Ranch, Supercrew- Stock for the time being
1991 Gt Alot of Team Z stuff, Strange stuff, Big round Percision thingy.
Sidewayzisbest is offline
post #2 of 9 Old 05-01-2004, 07:30 PM
hatches have to have a sealed box and be vented outside the car
86 coupe, 408,glide 101mm
810rwhp pumpgas tune...........
90lx351 is offline
post #3 of 9 Old 05-02-2004, 03:16 AM
RolledThatHo's Avatar
sounds like a waste just buy an already made box for like 10 bucks at wal-mart and if its not stout enuf which is will be if you set it up right then mod it from there
4 cyl stang...
my mod list
2 drilled holes in floorboard to drain the water
2 blown shocks from jumping the creek in my woods
busted side glass, cuz handle broke and i was pissed
spiderwebbed winshield
keyed paintjob
huge dint in front and rear from running through customers garage door then backing into customers mailbox (pissed again)
broke driver seat so swapped pass seat over there=seatless
headlights short on and off, due to beating on the top of the dash
dremel'd a hole in front of cats because they were clogged and catching on fire
btw i work for dominos!
RolledThatHo is offline
post #4 of 9 Old 05-02-2004, 09:30 AM
Deepstage's Avatar
Read the NHRA rules. If you have a hatchback, you need a sealed box with a minimum thickness. It needs to be vented to the outside. The battery also has to be held down by at least a 3/8" bolt I believe.
A plastic marine battery won't cut it. Here is a pic of my settup. It is a summit box.
They have since come out with a new aluminum box that does not bolt together. It is much nicer and has a good lid. I believe it is around $110. In my opinion, no nicer battery box exists. I was able to fit a heavy duty flamming river cuttoff switch, and the starter solenoid in the box along with an optima red top. Makes for a clean installation and keeps all the wires inside the box where they can't contact anything.
You are about to embark on a wiring journey which is not easy to do correctly. Wiring a rear mount battery in a EFI car safely and track legal is not easy. If not wired correctly, you may damage your alternator, computer, or create fire hazards. Do some research and you may find a few posts which are useful to give you more info.
If you really want some expert advice, contact Mark at Madelectrical.com
He can answer all your questions and tell you exactly why certain things should be wired a certain way. You may even learn a few extra things to boot.
Paul
Paul
Red 89' 25th Anniversary LX
DSS 347, AFR 185's, Victor 5.0 Intake, N-91 (hydraulic), 80mm ProM, 75mm TB, 30lb injectors, 255 Liter Fuel Pump, 1.6 Rocker Arms, 1 3/4 LTubes, 4.10s, 15x10.0" ET Drag
ET's --> [email protected] w/1.50 60ft
Deepstage is offline
post #5 of 9 Old 05-02-2004, 11:57 AM
jeremy mifflin's Avatar
i made a bat box out of 20 ga stainless
jeremy mifflin is offline
post #6 of 9 Old 05-02-2004, 08:50 PM Thread Starter
well my dad owns a misc steel company and i was goign to get a .13" alumn and get one of the guys to make a nice bead welds that similiar to the one thats not bolted but how would i keep the battery in there not moving?thanks for all the help
post #7 of 9 Old 05-02-2004, 10:23 PM
Deepstage's Avatar
You'll need a type of u-bolt that goes over the battery and down through the bottom of the box. Then securely fastened to the sheetmetal. This will most likely involve using some large fender washers to spread the load over the thin floorpan or making a custom bracket which is sturdy.
Paul
Paul
post #8 of 9 Old 05-02-2004, 10:40 PM
Formerly known as 20thAniv
Unatural's Avatar
Instead of a u-bolt, you can just use 2 long pieces of all thread, one on either side of the battery, with a piece to connect them that holds the battery down (basically making a u-bolt) and then a nut on each piece of all thread. That way if you want to take the battery out, all you have to do is take the nuts off the all thread and pull it out.
Wayne
'91 LX Hatch
Single turbo
, KWS Images on FB and IG
https://forums.corral.net/forums/turbochargers/1379238-unaturals-diy-build.html
Unatural is offline
post #9 of 9 Old 05-03-2004, 10:39 PM
buffhomer's Avatar
See if this pic works and you can see the way I did it (with the Taylor kit). I had to double nut the hold down since the nuts came loose once and the battery moved.
http://buffhomer.corral.net/images/taylor_box2.jpg
buffhomer is offline
