Battery relocated - has running a ground up front fixed any issues you've had? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 04-12-2004, 01:25 AM Thread Starter
Question Battery relocated - has running a ground up front fixed any issues you've had?
Did the standard battery relocation. Battery to the quad shock mount (frame) in the back, block to the frame up front. I know Pro-M preaches running a ground up front from the battery when their meters start acting stupid. I'm just curious what electrical issues have you had that were truely resolved by running a ground all the way up front? (aftermarket ignition, computer, fan, elec. grimlins, etc).
I'm just curious, thanks.
Eric88 is offline
post #2 of 8 Old 04-12-2004, 01:50 AM
Timmy2734's Avatar
kinda pointless, at least i think so. The ground, any ground for that matter, should be as short as possible
Timmy2734 is offline
post #3 of 8 Old 04-12-2004, 10:59 PM
Relocated mine using 1/0 weld cable for positve side to solenoid... 1/0 weld cable to quad shock....and a no. 4 braided cable from engine to sway bar bracket...checked battery voltage in back...12.58v...checked voltage at solenoid...12.58v...no problems here...
red1986gt is offline
post #4 of 8 Old 04-12-2004, 11:41 PM
Run a 2 gauge from bat to engine block. Put my 408 together and ran like sh** could'nt figure it out tried everything. Ran a cable from the battery to the block then it ran great. There is no frame in a mustang so if you ground it in the back it does not get a good ground. The ground does not travel through the uni body very well
scotty is offline
post #5 of 8 Old 04-13-2004, 12:58 AM
Scotty is right...I have welded subframes...sorry i didn't mention that...
post #6 of 8 Old 04-13-2004, 08:46 AM
NUTTSGT's Avatar
I have an 8pt cage and 2"x2" subframes, my neg goes to a nut welded on one of the back bars. Up front, I have solid motor mounts and a ground cable from block to front subframe. No problems here.
Eric
TOO MUCH IS...JUST ENOUGH
NUTTSGT is offline
post #7 of 8 Old 04-13-2004, 08:59 AM
Blk88GT's Avatar
I never had any issues when the car was a stock EFI 5.0, or the 408 with the grounding out back. Works like a charm.
Ian
1988 Mustang GT - 422w/IS plate
[email protected] (1.26 60ft) best 1/4 mile
[email protected] (1.31 60ft on the back tires) best 1/8 mile
Blk88GT is offline
post #8 of 8 Old 04-13-2004, 09:18 AM
Dac
I relocated my battery to the rear also. I ended up grounding my battery to the fuel tank strap bolt. I had a few problems until I ran a wire from the block to the fender skirt.
Dac is offline
Critique this problem...battery in the trunk kbscobravert Electrical & Wiring 5 07-19-2015 09:52 AM
need help with MSD 6AL install....(LONG horror story inside). bolt-on-bandito General Mustang Tech 34 02-17-2014 06:59 PM
Battery issues - no spark at terminal on fully charged battery mansonozz General Mustang Tech 5 04-18-2012 08:17 PM
For Sale Hawk Brake Pads FREE SHIPPING [email protected] Suspension 6 12-02-2011 12:35 PM
