trunk battery ground - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 03-28-2004, 11:27 PM Thread Starter
Where did you guys ground your trunk (hatch) located battery? Is it okay to gound it to the body sheet metal or do i need to hit the subframe? I plan on upgrading stock engine ground strap and I'm also running another engine ground? Right know i've got the battery grounded to one of the tailight bolts (with paint removed).
Thanks fellas
cham is offline
post #2 of 9 Old 03-28-2004, 11:59 PM
ForcedAir91GT's Avatar
Run your ground to the frame for best results. To a Quad-shock bolt works good. Also use a second ground up front.
ForcedAir91GT is offline
post #3 of 9 Old 03-29-2004, 12:31 AM Thread Starter
Through the floor to the quad shock bolt?
cham is offline
post #4 of 9 Old 03-29-2004, 12:42 AM
i welded two short 3/8" bolts to the body in the spare tire compartment to use as grounds
cjwanner2000 is offline
post #5 of 9 Old 03-29-2004, 08:31 AM
Yep, thru the floor. Use a rubber grommet & at least 1-gauge wire. You also
need to run a vent tube out of the car also. It means another hole also.
You will see the mounting plate for the Quad-shock that you can use if you remove your rear tire. Do a search on relocating your batt. A lot of info on here.
post #6 of 9 Old 03-29-2004, 12:43 PM Thread Starter
Thanks for the info. I think I'll go with your idea on the quad shock bracket.
cham is offline
post #7 of 9 Old 03-29-2004, 08:57 PM
jcm3's Avatar
This is a little bit more work, but it is a cool idea. When I had some suspesion work done on my car (welding), the shop offered to square away my bettery wiring. I had it done in kind of an ugly fashion, and they redid it for me.
They put a bolt in the battery box, welded the bolt and the nut to the trunk area, which created a built-in ground. Now my neg battery cable never even leaves the battery box, it is grounded right inside of it.
Not really suggesting that, the way mentioned above is easier and works great. Just a thought if you ever want to clean things up.
92 GT Vert, Keith Craft 306, SQ-Trim w/Power Cooler, Edelbrock 6037's/Performer intake, FTI cam, 60's, Walbro GSS340, T-56 6-speed, Spec Stage Three, Baer Brakes, Griggs Suspension, 3.55's. Best time - 11.56 @ 121.75, 1.78 60' on ET Streets (7.48 @ 95.69 1/8th) - with E-303 cam, 500 rwhp/463 rwtq
jcm3 is offline
post #8 of 9 Old 03-29-2004, 10:49 PM
ksstang's Avatar
Search for a person on here with the user name of Buffhomer. He has a very good article on his website for battery relocation.
Kyle
Kyle
1993 LX Coupe
1989 GT (Project Car)
I Understand The Jeep Thing..Thats Why I Drive A Z-71
ksstang is offline
post #9 of 9 Old 03-30-2004, 09:04 AM
Here is what it looks like in finished form;
So, you have two holes for the Batt-box, one for the ground, one for the vent-tube, one on the back panel for your cut-off switch. And, depending how you route your cables up to the front, you might need another up there.
I did my ground & vent holes behind the side trim panel so you wouldn't see them. Good luck on however you do it. The most important thing is your cable size, grounds, & keep it all away from moving parts & high heat areas. Use rubber grommets for all the holes. By the way,.. Buffhomers site is really a great site to go to to learn just about anything about it. I'm sure you can e-mail him and he would be glad to help you also.
Battery Cables? Duncan_GT General Mustang Tech 27 10-15-2014 08:31 AM
Tell me about your trunk mount battery set-up PritchSVT97 SVT & DOHC 9 06-17-2014 10:18 PM
underhood wire and splices. mr_minnis Electrical & Wiring 8 05-20-2014 08:39 PM
Where to Ground the Battery? gncmountainman Electrical & Wiring 5 05-15-2012 01:39 PM
ANybody that has moved battery to Trunk (thread moved from 94/95 Engine Tech) blackgtstang Electrical & Wiring 4 05-07-2002 11:22 AM
