1986 Mustang GT Dead Battery - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 03-23-2004, 05:33 PM Thread Starter
So I just got my 86 GT and went to start it up and nothing happened. It didnt click when I turned the key, no lights in the car work and the winshield wipers wont work. I went and got a new battery but the battery cables that are in the car now wont fit the new battery.
So is this a dead battery for sure or could it be something else? And where can I find just battery cables and not a battery relocation kit.
FuzzyGophar is offline
post #2 of 3 Old 03-23-2004, 08:09 PM
A couple of things:
Beg, borrow, steal a digital multi-tester. Set it on D.C. and check across the pos and neg terminals of the old batt. A fully charged batt is 12.66 V.
If you find the batt voltage low - check the water level in the batt. If low, (top of plates out of the water) -fill to within 1/2 " of the top using distilled or de-mineralized water only. Then try a charge.
Better yet - either take the new batt back and get one that will fit or - change the batt cable terminals, (usually $1.00 ea), so they will fit the new batt. If one cable is too short and the other is too long then you have to get a batt with the pos and neg terminals reversed.
When you get the vehicle started - check across the batt terminals with the meter. It should read 13.8 to 14.4 V, with all accessories ON, if the alternator is working.
bronzesink8 is offline
post #3 of 3 Old 03-23-2004, 11:55 PM
My alternator died just lately... I thought it was the battery , but turns out the bad alternator drained the battery...
89302 is offline
Rdrcrs 2013 Mustang GT Upgrades and Reviews Thread. Rdrcr S-197 Mustang GT (2011-2014) 62 12-11-2014 12:36 PM
For Sale 1986 Mustang Gt 306, AFR Heads, 5-Speed, Built Rearend---$5500 Dlohden Mustangs For Sale/Wanted, 1979-1986 2 11-21-2013 09:56 AM
For Sale 1986 Mustang GT - Green 86greenGT Mustangs For Sale/Wanted, 1979-1986 13 10-22-2013 11:44 AM
For Sale 1986 mustang gt 5 speed clean $2300 pa drexel Mustangs For Sale/Wanted, 1979-1986 3 05-20-2011 11:20 PM
