BATTERY RELOCATION - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 03-10-2004, 07:15 PM Thread Starter
Arrow BATTERY RELOCATION
I was thinking it would be a nice clean way if you could run the positive cable under the carpet of the interior to the battery box instead of attaching it to the framerails under the car. Would this be a possible problem if the cable was run under the carpet? Does the cable get hot enough to light the carpet on fire? Has anyone done this and how are the results? Thanks!
1991CALYPSO is offline
post #2 of 10 Old 03-10-2004, 07:28 PM
I have my positive cable run under the driverside carpet and have had it that way for 2 years now. No problems heating the carpet or with under voltage. I used a Taylor kit that comes with 2 gauge wire.
87five0 is offline
post #3 of 10 Old 03-10-2004, 07:51 PM
SVTCobraLTD's Avatar
I dont think it would. I know i have a 4gauge wire for my amp running under there and its fine. Been that way for years. Im thinking of just using that for the relocation and getting a new power wire for the amp. Would 4 gauge be enough?
SVT
PennMustangs - Owner
PennMustangs.com
1993 Ford Mustang Cobra SVT
465rwhp/460rwtq on Mustang Dyno
SVTCobraLTD is offline
post #4 of 10 Old 03-10-2004, 08:42 PM
I used 0 gauge wiring, and ran it through the panels on the car. It comes out near the door scuff plates, and runs underneath the carpet, then goes through holes I drilled in the floor
89 Sonic Blue SSP Coupe
Vortech V3 Si-trim, Powercooler, Maxflow bypass, AFR 165s, GT40 tubular upper, TMoss ported cobra lower, Forged Shortblock, Anderson Power pipe, 70mm Accufab TB, 42lb Inj, MM Adj. LCA, FRPP UCA, Wild Rides upper torque box, MM subframes, converted black interior, etc..
Keith 93 5.0 is offline
post #5 of 10 Old 03-10-2004, 10:15 PM
MdNiteDrftr's Avatar
I ran my cable under the driverside part of the carpet, you cant even tell its there.
I can take pics tomorrow if you'd like.
-Rich
1994 Ford Mustang GT vert
2001 Ford F250
MdNiteDrftr is offline
post #6 of 10 Old 03-10-2004, 10:41 PM
Formerly BLOWN1989SALEEN
Scott_0's Avatar
the only problem you may run into is when you run your alternator charge wire through the interior if it is run near your RCA cables or speaker cable you will get an annoying buzzing, when i did my relocation, i like a moron ran my charge wire right next to my RCA cable and i have this annoying buzz. BTW if your wire is getting hot then its not big enough, i recommend no smaller than 2ga and welding cable for the charge wire and 1/0 for the solenoid is what to use NOT auto cable.
Scott
Scott
2011 Ingot silver GT Brembo package, SVE drifts 19x9.5, Steeda Pro Action struts/shocks, FRPP K springs, GT500 strut mounts, BMR panhard adj. bar, Hushpower axle backs, Bama tuned
Scott_0 is offline
post #7 of 10 Old 03-11-2004, 08:05 PM Thread Starter
MdNiteDrftr: Pics would be cool
I also have a Taylor battery relocation kit.
post #8 of 10 Old 03-12-2004, 01:15 AM
Scott
Can't the charge wire just be connected to the solenoid where the battery cable comes into, so that only 1 wire and the ground would be needed? just wondering
SALAS331GT is offline
post #9 of 10 Old 03-13-2004, 09:52 PM
Scott_0's Avatar
yes the WILL work, but it WONT be legal at the track, to be legal the battery needs to be sealed and a cutoff switch needs to kill the car. if you dont plan on running at the track go for it.
Scott
Scott
Scott_0 is offline
post #10 of 10 Old 03-13-2004, 10:22 PM
parish99's Avatar
I ran my 1/0 cable on the passenger side and drilled the hole through the fire wall for the starter and a seperate wire on the drivers side for the charge. Not track legal but I dont really care either.
88 Coupe: 190lph, 73mm C&L, maf conversion,24lb injectors flowed @ matched, kirbon fpr, subframes,Pro-5.0, stewart water pump, 150 amp. Alt.,Ram chargers fan, battery relocate, Lincoln brakes in rear, 95 cobra up front, full autometer gauges,
parish99 is offline
99-04 Mustang GT Battery Relocation surtofak Electrical & Wiring 3 10-12-2015 10:43 AM
NHRA and battery relocation TomR Drag Racing 2 08-15-2013 06:20 AM
Battery kill switch/no battery relocation 97stanger97 GT & SOHC 11 06-10-2013 09:23 PM
For Sale NIB UPR Battery relocation kit, Complete** marlboroman8792 Electronics and Entertainment 6 11-05-2011 09:36 PM
