Power Windows Won't Go Up / Down - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 12-17-2003, 12:20 AM Thread Starter
My power windows don't go up/down. They are both brand new motors so I'm positive that is not the problem, also, you would hear at least the power going to the motor if it was dead. So, here's what I know so far:
-using a multimeter, we checked to see if power was there. it is getting power.
-checked all fuses, all fuses fine
-power locks still work
-air bag light is stuck on
So from those symptoms, anyone have any ideas how I can fix my windows? Anyone has a schematic? Thanks!
-Jessica
sexystang1994 is offline
post #2 of 8 Old 12-17-2003, 12:25 AM
Have these new motors ever worked?
If not, they are likely installed incorrectly.
These are a pain to reach, but they are not a difficult part to deal with. Perhaps the new motors are the wrong ones?
94GTVert is offline
post #3 of 8 Old 12-17-2003, 12:28 AM Thread Starter
Nope, they were installed correctly and yes it was a pain, but I have small arms so it was easier to get in there . They've been working great for the past 2 months from the install.
post #4 of 8 Old 12-17-2003, 12:34 AM
The switch itself is a spot that rainwater just loves to reach. I suspect that my own intermittent passenger side window is due to the switch or the connection at the motor.
I just hit the button over and over and it always comes back online. I gotta fix that...
Good luck. What is your plan?
94GTVert is offline
post #5 of 8 Old 12-17-2003, 01:29 AM
My passenger side didn't want to go up but went down no problem. It was the switch. i poppe out the switch and cleaned it and it still didn't work. then I cleaned the switch on the passenger side and it worked after that. Seams like the driver side switch is dependant on the passenger side one. Then a few weeks later I had the probelm with the drivers side so I cleaned it too and it works fine. What I did is popped out the switch opened it up with a small screw driver and cleaned the metal contact points with q-tips and alcohol. Be sure to bend the metal swtiches back into their origal shape or they might not work. Give it a try takes about 10min.
ford5p0 is offline
post #6 of 8 Old 12-17-2003, 02:00 AM
Thanks. I will try that with mine.
94GTVert is offline
post #7 of 8 Old 12-17-2003, 11:11 AM
94CobraPace's Avatar
Check switches, they are dependant of each other. Meaning if one switch is bad the other switch will not operate the window. New switches are about $40 each.
2010 Shelby GT500, Kona Blue W silver stripes.
2007 Shelby GT500, Vista Blue with Tungston gray stripes, 1 of 119, Wifes car...
94 Cobra Pace car Convertible # 591
2001 Cobra vert # 2001 SOLD
94CobraPace is offline
post #8 of 8 Old 12-17-2003, 03:56 PM Thread Starter
ok thanks!
also this might have something to do with it as well:
My aftermarket alarm (viper 550) is acting up too. It has the option of "auto start" and it won't start. You can set it up to have windows go "auto down" but I didn't have the installers put the code in. Although, maybe the buttons could have been pressed while my keys were in my purse to set the code? Who knows. This is so frustrating lol!
25 year old power windows FOXVERT91 General Mustang Tech 7 06-13-2016 10:03 AM
Power lock switch continuity (manual windows) GT80 General Mustang Tech 2 06-10-2015 05:53 PM
Want To Buy WTB red vert door panels w/ power windows tpoch845 Interior Parts 2 08-29-2014 01:55 AM
Man facing jailtime for owing child support commits suicide on courthouse steps MurPHy4570 Politics 96 02-19-2012 01:24 PM
power windows not working.. gtboggs88 General Mustang Tech 2 03-22-2011 01:59 AM
