relays - someone set me straight on Mark VIII fan install - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 10-31-2003, 06:26 PM Thread Starter
Exclamation relays - someone set me straight on Mark VIII fan install
So I'm dicking with the relay to get power to the fan but I have a weird (in my opinion ) problem. I can't get any power to the side that sends power to the fan at all. I'm hooking up my relay as follows:
30 - Positive power from battery (through a fuse link)
87 - Positive power to fan's positive terminal
86 - Thermostatic switch
85 - 12V source from red MAF wire
I hooked up my volt meter to the 30 terminal to make sure I have power. I had ~12V thank gawd, and the 87 does not (at least it shouldn't, heh). However, when I ground the thermo switch and the relay closes, I lose all power at the relay's terminals...even the 30 terminal. So in other words, once I ground the the switch, there's no power at either the 30 or 87 terminals. Why would this happen??
If I haven't provided enough info, please let me know. I'd really like to understand what's going on. Thanks...
Jordan G.
Blue 1990 LX coupe
Ford Motorsport 351 balanced shortblock w/ KB flat tops, TFS TW heads (port/polish/milled for 10.5:1), TFS 351 U&L intake, 76mm C&L MAF, 70mm Accufab TB.
Katter281 is offline
post #2 of 11 Old 10-31-2003, 08:49 PM
For a quick answer I would say that you have terminals 85 and 86 reversed. Keep in mind this is coming from an electrical moron. Worth a shot anyway.
D-2R ProCharged R302 331, 1.393 60 ft, 5.868 @ 123.119, 8.953 @ 155.80, 3400 lbs (with me), MM&FF Feature June 2003
John91coupe is offline
post #3 of 11 Old 10-31-2003, 08:59 PM Thread Starter
Pfff, yeah, electrical moron with a gorgeous 9-second car . Seriously though, thanks for the response...
Well, I did a search and from what I gathered, 85 and 86 are interchangeable. I might try changing them around tomorrow for grins if I don't get any other leads. Thanks again...
post #4 of 11 Old 10-31-2003, 09:23 PM
Oktavius's Avatar
What relay are you using? The 75A Bosch relays that I use do not have an interchangeable 85 and 86. 85 is negative and 86 is positive. Most other relays are interchangeable though. If you are not using the Bosch relay, I would try eliminating the thermoswitch out of the equation for test purposes. Just connect it to ground.
Tim ||||||| ||||||| |||||||
07 Subie Impreza - DD
92 GT SSP
XBL: Zexterr
Oktavius is offline
post #5 of 11 Old 11-01-2003, 11:24 PM Thread Starter
Thanks for the response Oktavius...
I am in fact using the Bosch 75amp relay also. I went ahead and tried switching the 85 and 86 posts with no luck. The relay closed, but I'm still losing power to the 30 and 87 posts?! Also, yeah, for simplicity's sake, I have been grounding the thermo switch on some bare metal.
post #6 of 11 Old 11-02-2003, 08:35 PM
I'm curious about the red MAF wire hook up. a relay would need two "grounds" right?
FISHSTUNTS is offline
post #7 of 11 Old 11-02-2003, 08:53 PM Thread Starter
I don't think I do, but I might be wrong.
I think you need a 12V source and a ground to close the relay, and a power source coming in, and a power source going out to the thing you want to power. I'm basically just following this pic I have (I think I stole it off this site, heh):
post #8 of 11 Old 11-03-2003, 12:43 AM
Oktavius's Avatar
I am stumped. I read through your post a couple of times and can't think of what is wrong. I dont understand how you couldn't read 12V power on the 30 terminal when the relay closes. It should read 12V no matter what position the relay is in, since you should be reading straight from the battery (well through a wire). I would check over your grounds again.
FISHSTUNTS is right about 2 grounds. There is terminal 85 on the switch side and there is terminal 87 on the power side which gets its ground after the fan. Just like the schematic above in the lower right corner.
92 GT SSP
XBL: Zexterr
Oktavius is offline
post #9 of 11 Old 11-03-2003, 12:59 AM Thread Starter
Heh, leave it to me to make the possible, impossible. Who'd have thought a freaking relay could be so difficult
I see what you and fish are talking about now. I mis-interpreted his post. Lemme get this straight...
87 - Positive power to fan's positive terminal <----So you're saying this eventually goes from the + terminal of the fan to a ground, right?
86 - Thermostatic switch i.e. ground #2
I guess I'm going to tinker with it tomorrow to see what I screwed up. If I can't get it right, I guess I'll call my mechanic and give him a good laugh
post #10 of 11 Old 11-03-2003, 01:13 AM
Oktavius's Avatar
That is the idea, but you still have 85 and 86 switched around. I know that mine would not work with them reversed. The diagram is right on the side of the relay.
92 GT SSP
XBL: Zexterr
Oktavius is offline
post #11 of 11 Old 11-03-2003, 01:29 AM Thread Starter
Well, even though this relay is still goofy, thanks a million for your input/help
I'm gonna switch the 85/86 tomorrow one mroe time and see what happens. Thanks Oktavius...
Mark viii fan info overload need help James Smith 5.0/5.8 Engine Tech 49 04-08-2016 11:50 AM
For Sale Custom Mark VIII Cooling Fans - Direct Bolt-in Fans! Caseywan Electronics and Entertainment 194 09-28-2014 01:55 PM
Want To Buy Mark VIII Fan shroud or fan with bad motor CPURTELLII Miscellaneous Mustang Parts 1 03-26-2012 12:46 AM
replacement fan blade for lincoln mark VIII electric fan stang331 5.0/5.8 Engine Tech 1 12-21-2001 01:10 PM
