battery relocation - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 10-08-2003, 04:55 PM Thread Starter
tording's Avatar
battery relocation
I am getting ready to relocate my batter to the back of the car. Do you pretty much just move the battery to the back and then run a postive wire up to the front to the solenoid and a negative to a good ground somewhere?? I am buying the kit from summit that comes iwth 20 ' of wire and all the brackets and everything. Also do you need to have a batter disconnect switch if the battery is in the back???
92 LX notch--Shorty headers--Pro 5.0 shifter--130 amp alt--U/D pullies--A/C delete--190 LPH FP--Compucar nitrous kit--FMS aluminum D/S--Elec Fan--Weld DL's--M/T ET Street--2900 lbs
13.8 at 100 mph - 2.0 60' - Motor
13.0 at 108 mph - 1.9 60' - 90 shot N2O
SOLD
tording is offline
post #2 of 16 Old 10-08-2003, 05:05 PM
Timmy2734's Avatar
use the search. Plenty of threads about it
Timmy2734 is offline
post #3 of 16 Old 10-08-2003, 08:25 PM
Rich G's Avatar
Trader Feedback: (35)
where did you find the part number from summit?
Rich G is offline
post #4 of 16 Old 10-08-2003, 09:02 PM
BigBoyBoelts's Avatar
Rich, Im looking at my Summit catalog right now and they are on page #83. Part # is
SUM-G1200A - Black Case
SUM-G1199 - Red Case
Now these kits are not legal for track use in a Hatchback, they must be mounted in an actual truck. They do sell Moroso's sealed box(#MOR-74050) that is legal for HB use.
Matt
-"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." - Frank Sinatra
Your only alive cause I haven't had time to kill you yet!
BigBoyBoelts is offline
post #5 of 16 Old 10-08-2003, 09:42 PM
Rich G's Avatar
thanks
Rich G is offline
post #6 of 16 Old 10-08-2003, 10:38 PM Thread Starter
tording's Avatar
my thoughts are that I never race at NHRA sanctioned events, only on street racing nights at the track so I doubt they will ever say anything about the box. I plan on sealing it anyway and running a vent tube down and out the car. the sealed boxes are so expensive.
SOLD
tording is offline
post #7 of 16 Old 10-08-2003, 11:29 PM
c4mustang92's Avatar
do a member search for buffhomer. He has a write up and diagram that will help you alot. Personally, I would say do it right the first time and put a kill switch and sealed box in.
Ray
92 coupe
TFS stage 2 twisted wedge Heads.TFS track heat intake.Ultradyne Cam.#24 inj.190 lph fuel pump.70mm TB.75mm MAF.1 3/4 Long Tubes.hpipe.Flowmasters.1.6 roller rockers.C4 reverse pattern.3000 stall.3.73.electric fan. eibach springs.battery relocation.3g Alt.MSD 6AL.Autometer Phantom Guages.99 Brakes.95 Rear End.93 Cobra brake booster.99 Cobra Wheels.Eaton Posi.Moser 31 Spline Axles.GP CC Plates.Diamond Clears
Originally posted by TBG
I wont die alone..Im taking people with me.
c4mustang92 is offline
post #8 of 16 Old 10-09-2003, 01:39 AM
Yeah I agree with Ray here, it might be cheaper to do it this way but make sure that the thing is either bolted down good, or welded. Because if not and you get into an accident, that battery becomes a 30# missile that will go through your passenger/ passenger area or you! Just be careful and think stuff through before doing it. Like the old saying goes measure twice cut once.
Matt
post #9 of 16 Old 10-09-2003, 11:39 AM
i have a old batter cut off switch laying around some where drop me a PM IF U NEED IT
s85stang is offline
post #10 of 16 Old 10-09-2003, 06:03 PM
TXLX's Avatar
I ordered some stuff from summit last night and was cruising the clearance section. They have some sealed aluminum battery boxes for somewhere around 45 bucks. Might be worth checking into....
Eric
89 GT
SN95 Suspension and Brakes w/ 03 Mach 1 wheels. GT40 Longblock, Edlebrock Int w/ 70mm TB, Pro-m, 2031 cam w 1.7's, MS shorties. B springs, Hotchkis rear arms,
06 F150 Super Crew
TXLX is offline
post #11 of 16 Old 10-09-2003, 09:38 PM
Rich G's Avatar
damn that sucks I just ordered one for 85
Rich G is offline
post #12 of 16 Old 10-09-2003, 11:14 PM
jcm3's Avatar
http://buffhomer.corral.net/custom.html
Yep, do it right. This is VERY cheap in the grand scheme of things. Why limit yourself to non-NHRA events? I was warned once about it at a local track, then I got one. At Bakersfield they would not have let me run without it.
Peace of mind.
92 GT Vert, Keith Craft 306, SQ-Trim w/Power Cooler, Edelbrock 6037's/Performer intake, FTI cam, 60's, Walbro GSS340, T-56 6-speed, Spec Stage Three, Baer Brakes, Griggs Suspension, 3.55's. Best time - 11.56 @ 121.75, 1.78 60' on ET Streets (7.48 @ 95.69 1/8th) - with E-303 cam, 500 rwhp/463 rwtq
jcm3 is offline
post #13 of 16 Old 10-09-2003, 11:55 PM
yeah, plus it can move if not held down right. Mine did, and one of the wing nuts on my positive hit the box and grounded to the chassis. Luckily, all it fried was the battery.
post #14 of 16 Old 10-10-2003, 12:17 AM Thread Starter
tording's Avatar
I didn't even know there was a clearance section on summit, maybe I will just go that route then.
SOLD
tording is offline
post #15 of 16 Old 10-10-2003, 06:23 AM
I did mine from the Buffhomer site and haven't had any problems what so ever! I have the race pullies and 130 amp 3G with no problems. I got my cable from a welding house supply, bought 2/0 cable and used that for everything. I'm using 200 amp fuses.
DSSR is offline
post #16 of 16 Old 10-10-2003, 01:44 PM
jcm3's Avatar
I had a guy at GRC in Mission Viejo rewire my trunk-mounted battery for me, and he did something I thought was really cool! He bolted the box down, then welded the nuts to the frame and put a small stud down through the nut. That way, the box can be attached by that, and the negative battery cable can also be attached directly to that, so it never needs to leave the box. For those that like that little bit of extra attention to detail, it just means one less cable needs to leave the box to be attached anywhere.
I thought that was kinda cool.
jcm3 is offline
99-04 Mustang GT Battery Relocation surtofak Electrical & Wiring 3 10-12-2015 10:43 AM
NHRA and battery relocation TomR Drag Racing 2 08-15-2013 06:20 AM
Battery kill switch/no battery relocation 97stanger97 GT & SOHC 11 06-10-2013 09:23 PM
Battery relocation - 1995 mustang cobradragger Electrical & Wiring 1 07-17-2005 01:42 AM
