Ignition switch replacement (Moved from 94/95 Tech) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 08-31-2003, 10:31 AM Thread Starter
Question Ignition switch replacement (Moved from 94/95 Tech)
Has anyone had any problems with the ign switch located under steering colum. I shut my car down and now the starter wont turn over. No its not seized and i checked the neutral safety switch, replaced starter, and checked connections. I need to check and see if im getting voltage at the starter but i suspect the ign switch. Do these go bad from time to time? Just wondering if anyone has had a similar situation. As soon as i get a break from work im going to check for voltage at the starter.
BUD LIGHT is offline
post #2 of 2 Old 08-31-2003, 12:57 PM
wazee's Avatar
I had a problem and addressed it here previously. Search by wazee. I took off the underdash plastic and metal plate. Make sure you have the correct bits. I believe there are two torx bits that hold the ignition switch on. I had to drill out the plastic holes and slid it toward the back of the vehicle and re-bolted. The problem is that you wore out the ignition switch past the point of contact when the key tumbler turns all the way. Kind of like the TPS drill out on a fox. The switch was good as new.I only had to drill and move 1/16-1/8 inch range.
wazee is offline
anyone relocated the engine compartment fuse box ? (Moved from 94/95 Tech) Heyitsme Electrical & Wiring 9 05-08-2012 06:28 PM
airbag light flashing (Moved From 94/95 Tech) namckethen General Mustang Tech 4 01-04-2003 12:43 AM
Anybody with electrical experience (Moved from 94/95 Tech) yellow95 Electrical & Wiring 2 08-02-2002 02:04 AM
Fan won't shut off (thread moved from 94/95 Tech) 95CobraofDeath Electrical & Wiring 2 06-25-2002 02:06 PM
No air out of center vents - help replacing vacuum canister (thread moved from 94/95 Tech) BLK90LX General Mustang Tech 0 06-24-2002 12:43 AM
