Charging Problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 07-24-2003, 09:29 PM Thread Starter
Charging Problem
After my battery relocation to my trunk, MSD 6AL install, electric fan Install, i had a charging problem.... this is what ive found, where am i now...
I had to push start it this moring, i drove it to the craft shop on post... when i got there i saw NEG cable had come off where it was attached to the control arm. (I drove it with no ground)
Now i have a good ground on the frame. It would not start, with my multimeter on the battery, it was around 11.5 volts or so, when i tried cranking it over, it dropped to about 3 volts, instantly. when i let off the key, it went back up to 11.5 after 20 seconds.
I hooked a charger up to it, and it started up NO PROBLEM.
Do you think my battery is killed now?!?!
craigm1841 is offline
post #2 of 2 Old 07-25-2003, 11:15 AM
FordRacer9's Avatar
Sounds like you killed a cell in the batt. Time for new.
89 GT AOD with all the bolt ons.
Reasonably priced PROFESSIONAL installs and side jobs done. PM me for info and pricing!
FordRacer9 is offline
fox charging issue kris k Electrical & Wiring 6 08-24-2014 11:53 PM
410 stroker weird overheating problem dbldrew 5.0/5.8 Engine Tech 1 09-28-2012 11:52 AM
Acute driveability problem driving me nuts. Sensors? Vacuum? ...new thread MFE 5.0/5.8 Engine Tech 62 04-27-2011 02:28 PM
charging system and wiring experts help me diagnose this problem demon357 General Mustang Tech 1 01-08-2002 09:09 AM
Fuel Delivery Problem Solved!! Blown46Cobra GT & SOHC 9 12-18-2001 01:44 PM
