1996 - 1998 taillights - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 04-04-2003, 01:24 AM Thread Starter
I like the way 96-98 tail lights look and would like to put them on my 95. So heres the question is there a difference between the 96-98 cobra light and the GT light.
67 coupe 289
74 Bronco full cage, D60,14bolt, 5.13's, and 40's
03 CTD 4x4 6 speed on 35's (crawler hauler)
67coupe is offline
post #2 of 11 Old 04-04-2003, 09:06 AM
Shawn95GTRag's Avatar
oops- n/m As far as I know there is no dif between the GT / Cobra.
Have you seen the '95 Export lenses?
Shawn
'06 Mercury Montego - FWD, 6-Speed ATX, Premier package
'02 Volkswagon Jetta GLS TDI - mods & MPG!
'95 Mustang GT Convertible 5Sp - SOLD
Shawn95GTRag is offline
post #3 of 11 Old 04-04-2003, 09:26 AM
Guarddog II's Avatar
between the 95 and 96 on up the wiring is slightly different. Haven't done the swap myself, but its not quite plug and play...but can be easily done as I understand it...
95GT Vert; Do you want a list of whats in my garage or whats actually on my car?
Guarddog II is offline
post #4 of 11 Old 04-04-2003, 09:45 AM
I had to get a wireharness from my Ford dealer. I think it was about $60.
FishStang is offline
post #5 of 11 Old 04-04-2003, 10:24 AM
you WILL have to get the wiring harnesses for the 96+ lights.
got mine from MPS.
Apollo_kid is offline
post #6 of 11 Old 04-04-2003, 10:50 AM Thread Starter
I think I can get a harness from the local junk yard. I just wanted to know if the cobra lenses looked different from the GT's . B/C everytime I see a 95 with 96-98 lights they say O yeah those are cobra tail lights.
Thanks for the responses.
67 coupe 289
67coupe is offline
post #7 of 11 Old 04-04-2003, 01:47 PM
OutLawSE's Avatar
All you have to do is go to the local part store and get 2 standard size bulb sockets. The 94/5 harness have to tiny outer sockets unlike the 96+ lights which use the standard size plug.
$5 and alittle sodering and you're good to go.....
1995 Mustang: Stalker Vortech-Trickflow 302
1994 Mustang: Built 306 with Trickflow Set-up
Nitrous, Boost, NA ..... Tried it all
OutLawSE is offline
post #8 of 11 Old 04-05-2003, 01:18 AM
SN95LEEN's Avatar
got mine from MPS.
This is one of the biggest myths about the 96-98 tail light swap...unless you are very very picky about something no one will ever see, then get it, otherwise there a few work arounds you can use...having the harness isn't a live or die necessity for doing this...and the wiring itself is the same (you don't have to change anything).
In my scenario it WAS a plug and play deal...literally took me all of 20 min. start to finish and I turned the key and drove to work. The only problem is the lower (I think, may be the upper) outer most bulb, as Outlaw said the bulb socket is a bit too small for the actual tail light assembly...the whole where the socket 'twists' (you'll see what I mean when you start on it) into is a bit too big...I think about an 1/8th of an inch on each side, not much at all. I simply used some adhesive putty I had, it doesn't harden like something similar to JB weld, it's very sticky and just stays in a putty state, but it's still flexible so I can remove the socket if the bulb dies out. I just had the bulb surounded by some of that stuff and it hasn't budged since...I'm in college so the free way was more appealing to me Another friend just used a couple sections of 3M tape to secure it, he's never had problems either. So you really don't 'need' the harness, unless you want it too look totally factory, which is totally understandable...but who is ever going to see that part of your car? JMO...HTH.
Originally posted by Anaconda
"...your sig sucks..."
SN95LEEN is offline
post #9 of 11 Old 04-05-2003, 02:45 AM
nope no differences for cobra lights only the 93 cobra and the newer cobra can't remember which year maybe 99 or 01 had different tails I think.
CanIhaveGASscash is offline
post #10 of 11 Old 04-09-2003, 12:07 PM
95KBconv's Avatar
FWIW, I just checked www.fordpartsonline.com for a price and they do list different assemblies for Cobra. Not shure what the difference is though. I can check my SVT brochures and see maybe.
Anyone know where to get a real set at a decent price? Pacific green.
Thanks, John
1995 Ford Cobra w/IRS, white - Coyote swap with full MM front end in progress.
1994 Ford Lightning, red - HCI and Kooks in progress.
1993 Lexus LS400, grey - stock
2003 Infiniti M45, black - stock
95KBconv is offline
post #11 of 11 Old 04-09-2003, 06:48 PM
I went and checked fordpartsonline, and it looks like the only reason that they have the Cobra listed is for the Mystic paint color. The non cobra one contains all the other factory body colors. At least, that is what it looks like.
Scott
Scott Gladney is offline
For Sale 1996 - 1998 Cobra coolant crossover pipe, powdercoated gloss black - $50 Tabres Modular Engine Parts 1 12-03-2015 12:31 PM
For Sale 1996 - 1998 Cobra alternator bracket - $20 Tabres Modular Engine Parts 0 11-23-2015 08:52 PM
For Sale 1996 1997 1998 Cobra Intake Manifold - Upper and Lower Maddmax Modular Engine Parts 3 05-08-2012 12:51 PM
1998 taillight install & sequential taillights FOR 1995 GT bjohn Electrical & Wiring 6 01-23-2003 11:28 PM
1994 1995 or 1996 1998 Export Taillights SHNYROQ The Body Shop 7 11-12-2002 11:16 AM
