1995 COBRA TACHOMETER WIRE FOR SHIFT LIGHT - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-25-2003, 11:54 PM Thread Starter
95 cobra... need to know what color the tack wire is, so that I can install shift light.
2000 Saleen S281SC #608, 42's,mass-air,long tubes,a few suspension pieces.
aaron427 is offline
post #2 of 4 Old 03-26-2003, 12:32 AM
I believe it's green. I can look in the shop manual in the AM if you can wait that long.
SlowGT is offline
post #3 of 4 Old 03-26-2003, 01:11 AM
It is Grey with an orange stripe, or Dark green depending on which harness is used. You can find it at the EDIS module which is just below the air box on the passenger side (will be in a 12 pin plug). You could also go straight to the coil, but this will make things a little neater looking under the hood.. (instead of having a wire tapped into the coil right on top of everything). Which ever of these colors you find at the EDIS plug, use it and you will be fine..
ONDGAS is offline
post #4 of 4 Old 03-26-2003, 01:16 PM Thread Starter
Thanks guys I figured it out.
aaron427 is offline
For Sale 5.3 big bore mmr 950s stroker t56 kb's and 20k in parts 99v6red Modular Engine Parts 3 09-13-2013 08:30 PM
1994 - 95 Cobra grille: pony or snake? 1oldfox 94/95 Tech 57 04-19-2013 11:53 PM
SOLD 1995 Mustang GT ( Cobra Clone ) outlawmustanglx Completed Sales 10 08-08-2012 11:46 AM
For Sale 1995 Crystal White Cobra Clone 5.0 NativePony Mustangs For Sale/Wanted, 1994-1998 5 03-07-2011 02:54 PM
