Weird dome light problems - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 03-22-2003, 02:16 PM Thread Starter
Got a weird problem with my car. The power is dead to all lights, Ie: dome light/trunk light, the personal lights by the dome.
Basically the car is dead untill I turn the key, or turn the headlights on.. then all the lights work, for a while.. After sitting for a few hours, nothing works again untill I turn the key, or pull the headlights on.. The outside doorhandle light wont work when u lift it at all..
Anyone know what could be the problem?
Thanks for the help!
94 cobra
94COBRA3182 is offline
post #2 of 2 Old 03-23-2003, 01:55 PM
bso
bso's Avatar
I had a similar problem of ligths not working, it was due to the vanity mirror light on passenger side had a crimped wire from the factory where it bolts up to the head liner. After checking all the wiring in the #8 fuse I finally found the short at the vanity mirror. Your dome lights are part of the #8 wiring, including: Dash lights, vanity, and glove box. I recomend for you to check for a short in all the wiring.
bso
bso is offline
Dome light comes on with low beams fast94gt Electrical & Wiring 2 03-20-2017 11:29 PM
Electrical issues. Turn signals, radio, dome light ect.. svostyle Electrical & Wiring 3 04-29-2014 08:42 PM
1999 GT dome light fuse #7 blows at startup? 35thPonyGT GT & SOHC 0 07-14-2013 02:20 AM
Want To Buy WANTED - 93 mustang Roof Crossmember for dome light Twinturbohow Interior Parts 3 03-22-2012 07:58 PM
Where does dome light harness tie in? TxFireman1972 General Mustang Tech 1 03-17-2012 10:57 AM
