WHY DOESN'T MY COOLING FAN TURN ON? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 03-19-2003, 09:13 AM Thread Starter
Hey everyone, for a while now my cooling fan will not turn on. I have tried everything, and replaced anything connected to what turns it on and off etc. I have replaced both temp sensors, the one that screws into the lower intake and controls the temp gauge, and the other one that screws into the water rail thing on the passenger side of the car. I have also replaced the CCRM and that changed nothing. I had to resort to installing an aftermarket fan control unit, since I never figured out what was wrong. I want to fix the original fan controler becuase the aftermarket one is giving me problems. I tested the ground on the connector and its grounded, but the hi and low power never go on. I've had this problem for a long time now, and I think it originated ever since I pulled the motor etc. Is there anything special fuse or something I have to ground, im getting realy desperate ANY HELP WITH BE APPRECIATED. Thanks
EXTREMEPAINT95COBRA is offline
post #2 of 16 Old 03-20-2003, 11:08 AM
We had the same problem, replaced everything you described and more.
If you figure it out please let me know what you came up with.
puckbunny is offline
post #3 of 16 Old 03-20-2003, 03:11 PM
Have you tried replacing the motor?
Albert
KingCobra500 is offline
post #4 of 16 Old 03-20-2003, 08:02 PM
I know what it is I did all the things that you tried. There was a recall on the electic fan. What it did was it burned up the motor in the fan so you have to take it to a Ford garage and get them to replace the whole fan unit.
Lazerstang95 is offline
post #5 of 16 Old 03-20-2003, 09:08 PM
Join the club! I did all that and more... finally ended up wiring it to a switch. I definitely have the wiring problem narrowed down to somewhere between the front and rear bumper.
I even installed the recall kit (which was really just a circuit breaker).
post #6 of 16 Old 03-20-2003, 09:27 PM
Anaconda's Avatar
I bought a new fan and ran a new wiring assembly to a switch. It is totally independent of the CCRM. Works great.
Anaconda is offline
post #7 of 16 Old 03-20-2003, 10:41 PM
UNAUTHORIZED ADVERTISER
NITROSTANGRACING's Avatar
Obviously you guys have all experienced the typical Ford Electric Fan problems. Did anyone ever think of checking the wires between the ECM and the CCRM. Within the circuit there are wires that run to the ECM. You need to get a wiring diagram of the complete circuit and start back probing wires at the ECM. You will need a good Volt/Ohm meter to do this properly.
My Mom says that if I keep violating the forum's rules about signatures and advertising, I'll just be banned altogether.
NITROSTANGRACING is offline
post #8 of 16 Old 03-21-2003, 01:26 PM Thread Starter
Thanks for the replies. THe fan is not bad, when i bypass the CCRM the fan works fine, on HIGH and LOW mode. NITROSTANGRACING, how will I go about testing the cwires between CCRM and ECM, the ECM being what exactly? Thanks for the help though
post #9 of 16 Old 03-21-2003, 11:20 PM
To go ahead and check those wires you really need to be good with electric. Do you know anyone in your area with ALLDATA or MITCHELL ON DEMAND? You will need to pull out the wiring diagrams for the fan circuit. You should also pull out the trouble shooting tree to check for your problem. With the Diagrams you need to make sure you have the PIN chart for the ECM. See what you can do to get them and get back with me and I can trya nd help you. If you send me the specifics on your car I might be able to get what you need and send it to you.
post #10 of 16 Old 03-22-2003, 01:37 AM
wow.. and i didn't even think about the recall that i didn't have done when i noticed i'm having fan problems too
mine doesn't seem to come on like it used to.. the temp gauge creeps up all the way to A or L before i get scared and turn on the A/C to get the fan to kick in.. at least it tunrs on at that point.
mgranzow is offline
post #11 of 16 Old 03-22-2003, 10:39 AM
Mgranzow----your problem seems like you mighjt have a coolant temps ensor going bad. Unplug it and check continuity between the two posts and see what it is when it is cold. The easiest way to explain it is the lower the number the better. If the coolant temp sensor gets varnished it can cause a delay in you fan signal.
post #12 of 16 Old 03-22-2003, 10:59 AM
i had the same problem when i installed my 95 5.0 engine! i tried everything just as you guys did. i also checked my fuses, they didnt appear burnt but obviously were. as soon as i replaced it the fan kicked on.
try replacing the fuse for yuor fan. it's in the engine bay fuse box. tell me what happends.
BottleFed95GT is offline
post #13 of 16 Old 03-22-2003, 11:05 AM
EXTREMEPAINT, your ECM is the engine control module.
post #14 of 16 Old 03-22-2003, 11:10 AM
sorry, it's Electronic Control Module. it controls all of your sensors. ignition module, fuel pump, oxygen sensor, intake air temp., vehicle speed sensorcoolant stuff liek that. it pretty much controls all functions of fuel inejction, using an array of sensors and switches to do so..
post #15 of 16 Old 03-22-2003, 12:57 PM Thread Starter
Hey Bottlefed, if it is what you say, i will seriously kick myself in my ass. I do remember the box getting a little wet when the cover was off, so maybe something did burn inside it. Do you remember which fuse number it was or how many amp fuse it was. Thanks alot for the replies, i realy hope i can recolve this problem!
post #16 of 16 Old 03-22-2003, 11:56 PM
sorry i dont rememebr exactly which fuse it was. ill look ASAP. but i used a 25 amp fuse for it. it was orginally 30 i believe? but the 25 works excellent! ill look possibly in the morning.
Radiator fan wont turn on without ac + ac problem Jay.GT S-197 Mustang (2005-2010) 8 03-24-2017 12:27 AM
Folks in southwest US - fan turn on/off temps and coolant? DuffManRHA General Mustang Tech 6 08-20-2016 12:07 PM
Intermittent cooling fan issue 99FiveOh 94/95 Tech 8 12-02-2012 02:20 PM
HELP!!! Radiator Replacement Cooling Fan Will NOT Work! Sonic Blue Snake SVT & DOHC 10 08-10-2012 10:31 PM
What Coolant/Antifreeze Do You Use? BTJustice GT & SOHC 13 12-26-2011 06:25 PM
