Battery Relocation - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 03-19-2003, 07:04 AM Thread Starter
Battery Relocation
I mounted my battery in the trunk.Im using 1 guage welding cable a positive and negative leads.Im running both + and - from the battery to the engine compartment. My ??? is where do i pass both cables through the fire wall? There seems to be no place to pass both cables, do to the fact that there so thick.
THANKS
1993 Mustang LX 5.0
306
Paxton Novi2000 12psi
Trickflow Track Heat Heads
Trickflow Street Heat Intake
Trickflow Stage 2 cam
Scorpion 1:6 RR
70mm BBK TB
80mm Pro-M Shorty
PowerPipe
42# Injectors
BBK 1 3/4 Long tube
Flowmaster Catback
Crane HI-6/MSD Coil
Every other Bolt on available
518 RWHP 478 FT-LBS
tonyv is offline
post #2 of 3 Old 03-19-2003, 08:24 AM
what i would do is run the cables under the car...
drill some holes above the rear axle, put a rubber gromit in there and some cocking around that. then just run them up there
BIGRYANKP is offline
post #3 of 3 Old 03-19-2003, 10:45 AM
90GTVert's Avatar
i ran mine into the passenger compartment, under the carpet on the drivers side, and out a hole i drilled in the firewall that goes inside the fender (where i relocated my starter solenoid). simple enough, and you cant tell its under the carpet.
90GTVert is offline
99-04 Mustang GT Battery Relocation surtofak Electrical & Wiring 3 10-12-2015 10:43 AM
NHRA and battery relocation TomR Drag Racing 2 08-15-2013 06:20 AM
Battery kill switch/no battery relocation 97stanger97 GT & SOHC 11 06-10-2013 09:23 PM
Battery relocation - 1995 mustang cobradragger Electrical & Wiring 1 07-17-2005 01:42 AM
