installing manual fan switch - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 03-17-2003, 01:52 AM Thread Starter
does anyone have a web site or step by step instructions on how to install a manual fan switch? i want it to use the stoc setting around town and stuff, but i want to be able to turn it on high so i can cool it off at the track. thanks guys
2004 Cobra, silver and mostly stock
2010 Top Sportsman Mustang, 645 BBF. [email protected]
'68 Cougar with a cleveland 408 and a C4. true footbrake car. [email protected]
spacecaptan is offline
post #2 of 14 Old 03-17-2003, 02:31 AM
Sinful's Avatar
Trader Feedback: (35)
Re: installing a manualy fan switch?? who's got the info??
i would like to know this as well.
Sinful is offline
post #3 of 14 Old 03-17-2003, 03:28 AM
MontAddict's Avatar
same here
let class begin
MontAddict is offline
post #4 of 14 Old 03-17-2003, 05:24 AM
slantman's Avatar
too simple for a class but here it is
http://bellsouthpwp.net/s/l/slantman/COOLING.htm
GT 40 long block gt 40x heads, B303 cam BBK 70MM TB, EDELBROCK PERFORMER RPM , MAC COLD AIR, KIRBAN ADJUSTABLE FPR , TWEECER RT.
FMS 30LB Injectors, PRO-M 75 MM Mass Air Sensor, MSD Pro Billet distributor, Msd Blaster coil, Crane HI-6S Igniton.
BBK 1 5/8 EQUAL LENGTH HEADERS, STAINLESS STEEL 2 1/2 H PIPE, Mangnaflow Polished SS 2 1/2 Cat Back, 3 1/2 Tips
via 1200mhz carputer, gps, mp3 ,dvd
1968 firebird 400
1996 sts 4.6 DOHV NORTHSTAR
slantman is offline
post #5 of 14 Old 03-17-2003, 07:55 AM
all you have to do is use a switch to ground the #17 wire coming off your CCRM...i think it is green/purple in color....just splice in a wire....run it to your switch...then run a wire from the other side of the switch to a chassis ground. the diagram above is perfect
94Fauxbra is offline
post #6 of 14 Old 03-17-2003, 08:35 AM
Sinful's Avatar
so this is for the high speed only? and the ECU will still control it in case i forget?
id like to run mine at low speed at all times. and high at the track
dave
Sinful is offline
post #7 of 14 Old 03-17-2003, 03:14 PM
the ECU should still control the fan as before...however i cant say for sure because i never let my motor get that hot
post #8 of 14 Old 03-17-2003, 08:37 PM
slantman's Avatar
I went with the low speed switch, was not happy with the amount of current the high speed fan pulled. you could actually see the rpms drop when the high spped fan relay pulled in.
1968 firebird 400
slantman is offline
post #9 of 14 Old 03-17-2003, 08:49 PM Thread Starter
i only plan on using the fan when in the pits cooling off. what do you mean you could see the rpms drop when the fan pulled in? do you mean the revs went down when you flipped the switch?
post #10 of 14 Old 03-17-2003, 09:08 PM
slantman's Avatar
yes that is what I mean. at idle it will damn near stall the car, the lights go dim for a sec. of course my car car idles very low any way.
1968 firebird 400
slantman is offline
post #11 of 14 Old 03-17-2003, 09:55 PM Thread Starter
so do you think it would be bad for the battery to run it with the car off?
post #12 of 14 Old 03-17-2003, 09:58 PM
Sinful's Avatar
how can i set the fan on low speed manually - w/ switch?
Sinful is offline
post #13 of 14 Old 03-17-2003, 10:19 PM
slantman's Avatar
look at the diagram low speed
unlike the high speed which only needs a ground on pin 17
the low speed needs 12v to pin 14
1968 firebird 400
slantman is offline
post #14 of 14 Old 03-18-2003, 12:01 AM
Sinful's Avatar
thanks !!!!
Sinful is offline
Help with wires to hvac fan switch (foxbody) Mstng93SSP General Mustang Tech 4 07-24-2016 03:44 PM
Electric Fan selection and wiring on a single switch w/o temp or speed control BlowThisRacing Turbochargers 17 10-24-2015 10:46 AM
New (to me) fan control that wont burn out your ccrm yellow95 Electrical & Wiring 4 10-23-2002 12:24 PM
Fan running when I turn on the switch Yel95 Electrical & Wiring 0 09-09-2002 09:28 AM
Manual Cooling Fan Switch mudanoman GT & SOHC 1 12-12-2001 01:15 AM
