wiring info: Which wire is LOW SPEED FAN ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 03-15-2003, 02:31 PM Thread Starter
Don't know if this made it through the 1st time??????
Which wire off the CCRM is the LOW SPEED FAN? I know high speed is #17 G/P
PH112 is offline
post #2 of 5 Old 03-15-2003, 03:36 PM
slantman's Avatar
this is what I found
GT 40 long block gt 40x heads, B303 cam BBK 70MM TB, EDELBROCK PERFORMER RPM , MAC COLD AIR, KIRBAN ADJUSTABLE FPR , TWEECER RT.
FMS 30LB Injectors, PRO-M 75 MM Mass Air Sensor, MSD Pro Billet distributor, Msd Blaster coil, Crane HI-6S Igniton.
BBK 1 5/8 EQUAL LENGTH HEADERS, STAINLESS STEEL 2 1/2 H PIPE, Mangnaflow Polished SS 2 1/2 Cat Back, 3 1/2 Tips
via 1200mhz carputer, gps, mp3 ,dvd
1968 firebird 400
1996 sts 4.6 DOHV NORTHSTAR
slantman is offline
post #3 of 5 Old 03-15-2003, 04:12 PM
slantman's Avatar
after furter testing pin 14 (dark blue) requires 12v to pull the low fan relay in, unlike pin 17 that requires a ground to pull the high speed fan relay
1968 firebird 400
slantman is offline
post #4 of 5 Old 03-15-2003, 05:08 PM Thread Starter
thanks........
EVERYONE! LOOK FOR A VERY INCLUSIVE POST ABOUT HOW I SOLVED MY FAN PROBLEMS / OVERHEATING IN THE NEAR FUTURE.
Pete
PH112 is offline
post #5 of 5 Old 03-15-2003, 05:20 PM
slantman's Avatar
HERE TRY THIS
1968 firebird 400
slantman is offline
FiTech EFI Install in an sn95 5.0 with stock gauges millhouse 5.0/5.8 Engine Tech 330 09-06-2017 09:50 PM
Low Speed fan isnt working 4PointQuick General Mustang Tech 2 10-23-2014 03:58 PM
Why does everyone put Mark VIII fans/parts in their cars? Mach1Man04 5.0/5.8 Engine Tech 95 08-11-2014 09:58 AM
Taurus fan single speed wiring? d-rail1976 Electrical & Wiring 19 07-23-2014 10:07 PM
Bondurant Electrical Wiring Fan CCRM A/C WOT Cutout Modification rallycobra Road Racing/Auto X 1 06-26-2012 12:24 PM
