Dome Light will not shut off - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 03-10-2003, 12:11 AM Thread Starter
1994Snake's Avatar
Last fall after working on my car i noticed that my dome light was on after starting it back up and it will only shut off if i remove dome light. I had put in my new heads and i remember disconecting my alarm siren and hood switch i am wondering how this would happen and what i can do do fix. Any ideas or suggestions? It is kinda annoying since the car only has 30k original miles and i feel like the car is already rigged up.
1994Snake is offline
post #2 of 11 Old 03-10-2003, 12:15 AM Thread Starter
1994Snake's Avatar
By the way if you didnt see my user name the car is a 1994 Cobra.
Rick
post #3 of 11 Old 03-10-2003, 01:25 AM
Not to be a smartass, but is the headlight knob turned to the left? If so, turn it to the right.
AaronK is offline
post #4 of 11 Old 03-10-2003, 02:30 PM
P63
Moderator
P63's Avatar
Trader Feedback: (15)
What aaronk said. Turning the headlight knob full ccw turns on the overhead light.
Victor Marshall
Copyright 2019.
P63 is offline
post #5 of 11 Old 03-10-2003, 06:55 PM Thread Starter
1994Snake's Avatar
I knew that much but thanks anyways guys. I installed all the parts on my car i would hope i knew how the light switch itself worked. Thanks for the vote of confidence and ability.
RIck
336CI Billet Internals / Billet 80mm Snail = Daily Driven
Hubcaps and Wheel Covers - WheelCovers.Com
post #6 of 11 Old 03-11-2003, 02:13 PM
P63
Moderator
P63's Avatar
It's possible, then, that the light switch doesn't work properly.
Or one of your door-switches isn't working right. It would probably be your passenger door, because if your driver-door switch wasn't working then you'd hear an alarm.
Victor Marshall
Copyright 2019.
P63 is offline
post #7 of 11 Old 03-11-2003, 07:08 PM
Re: Dome Light will not shut off. Please Help
I got a problem /w mine too, it dosent work right..
sometimes it go's on and off, some times when i exit the car, the light wont stay on for 30 seconds, sometimes it dose.. sometimes when i pull up the door handle the light goes on like it should, sometimes it dosent.. it allways works right when i open the door, just the other functions are wacked..
anyone have any ideas?
94COBRA3182 is offline
post #8 of 11 Old 03-12-2003, 08:38 PM
everything but the dome light work right???
Javygt50 is offline
post #9 of 11 Old 03-12-2003, 08:40 PM Thread Starter
1994Snake's Avatar
Otherwise everything works perfect.
post #10 of 11 Old 03-12-2003, 09:31 PM
mayo302's Avatar
ditto
Mine does this too, and the only thing that I have noticed is that if I don't unpug my radar detector or christmas lights (see avatar) before I turn the car off, the light will stay on until I unplug them and flip the key to run then off again, then it turns off.
(((I am not sure of this correlation, however, because occasionally the light still won't come on correctly when I disarm the car and open the door)))
1994snake, please dont feel like those people didnt have confidence in you, sometimes it is when you are the one who knows what you are talking about that you overlook the obvious, and I think that they just wanted to make sure you eliminated that.
Does anyone have a definite fix or cause of this? also, to those others with this problem, do you have anything (like christmas lights or radar detector) that keeps on when you turn the car off? maybe if you guys do too, then I can turn my theory into "scientific fact"
Matt Freeman '95 GT T-5, ... email mayo302 (at) gmail.com
mayo302 is offline
post #11 of 11 Old 03-15-2003, 12:49 AM
dome light
after deinstalling some crappy car alarm that went off every 10 seconds after i bought my 94 gt ,every time i would put the car in gear it would turn on but not when it was in park , does any body have a clue ? I took a hammer to the alarm after doing an oil change , with it going off 3 times in five minutes under the car , i think i disconnected all the wires thanks for any help , dome lights are highly underated!
real94stang is offline
Need a dome light for a 89GT with a sunroof quick50stng Miscellaneous Mustang Parts 2 06-12-2016 12:31 PM
Upgrading from '89 to '93 dome light Shaker666 General Mustang Tech 2 05-21-2016 04:25 AM
Electrical issues. Turn signals, radio, dome light ect.. svostyle Electrical & Wiring 3 04-29-2014 08:42 PM
2k GT Dome Light Wiring Diagram 2kGT420 Electrical & Wiring 0 03-08-2014 06:04 PM
For Sale Mustang dome light 1992-1993 johnson93gt Interior Parts 4 03-16-2011 07:01 PM
