A different battery relocation question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 02-25-2003, 09:00 AM Thread Starter
Down's Avatar
Here's my situation: I've got my battery in my trunk, and I'm wanting to go ahead and put it back underneath the hood. I didn't do the conversion, so I'm at a bit of a loss as to what I need (I would guess just the battery tray?) and how to properly wire it up. I would just "shorten" what I've got now, but this seems to be quite a hack job that was done on it. I thought about just getting a Haynes manual, but I don't know how in depth it would be, considering most cars already have all this stuff in place.
Any ideas of where I could find this info would be appreciated.
J
Member- DarkManRacing
89 LX-H/C/I/[email protected]
95 GT-H/C/I-Slow as sin
Down is offline
post #2 of 6 Old 02-26-2003, 10:45 AM Thread Starter
Down's Avatar
to the top with you
Down is offline
post #3 of 6 Old 02-26-2003, 11:02 AM
what year is the car, and what alt is in it. it is really easy to do. you right just shorten the wires and get a battery tray. buffhomer has some really good pics of his intallation for a trunk mount. just back step from thoose.
post #4 of 6 Old 02-26-2003, 11:19 AM Thread Starter
Down's Avatar
That would help, huh? It's an 89. I'm going to be upgrading to a 130A alt. when I move the battery.
Thanks,
J
Down is offline
post #5 of 6 Old 02-26-2003, 12:04 PM
Mount the battery tray and battery in the original location. Run a new 8 guage wire from the 130 amp alternator to the starter relay (battery post of course). If the starter relay isn't underhood already, move that to the original spot as well. A 4 guage or thicker cable should be run to the starter from the relay, as should a heavy cable from the battery positive post to the relay (battery post of course). Ground the battery to the original spot on the motor (driver's side I think) and I'd run a 10 guage wire from there to the vehicle body and/or firewall. Not knowing what you got already, that should get you in the right direction to start.
CASturbo is offline
post #6 of 6 Old 02-26-2003, 12:31 PM Thread Starter
Down's Avatar
There we go...
Thanks a lot
J
Down is offline
