High Speed Fan Works, Low Speed Doesn't - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 02-25-2003, 08:12 AM Thread Starter
Angry High Speed Fan Works, Low Speed Doesn't
My low speed fan does not work. The car will get to "M" then the high speed will kick on. I never see the low speed kick on.
The only time the low speed fan works is when I do the KOEO test. During the KOEO test, I see and hear the low speed and high speed fan cycle.
What could be the problem? I just don't have a clue here!
Thanks!
Pete
PH112 is offline
post #2 of 10 Old 02-25-2003, 12:19 PM
VibrantRedGT's Avatar
Low speed wire is fried. I've already been thru this. It may look OK but high voltage has most likely messed it up. Cut, splice and manually plug it into the fan with a female connector.
2006 GT
SLP Axle Back, K&N Drop In, Pioneer Navigation / DVD System.
VibrantRedGT is offline
post #3 of 10 Old 02-25-2003, 04:20 PM Thread Starter
Yeah that maybe the case for some people. but "It does turn on when I run the KOEO test." If the wire were messed up wouldn't it not turn on at all?
PH112 is offline
post #4 of 10 Old 02-25-2003, 07:33 PM
95GTfiveOh's Avatar
Try replacing the Coolant sensor. It's happened to me twice in the past where my low speed fan wouldn't turn on anymore, and the first time, for months, I couldn't figure out what was wrong. Turned out to be that stupid sensor. It's real cheap at Autozone for like $16, and you get a warranty on it. If it goes out again, go go replace it for free.
95GTfiveOh is offline
post #5 of 10 Old 02-25-2003, 07:46 PM
i have the same problem. are you talking about the coolant sensor for the temp guage or the ECT sensor?
94 gt - MM suspension, edelbrock intake, 2031, afr's, s-trim 6psi, 403hp/404tq (no new numbers at 9psi)-For Sale
06 Mazdaspeed6
5ptSlow is offline
post #6 of 10 Old 02-25-2003, 08:57 PM
95GTfiveOh's Avatar
THe electronic coolant temperture sensor (ECT). It's right next the thermostat housing. Just unplug it, unscrew it out, put the new one, and you are set to go. The temperature sending unit is what controls your guage inside the car. It's wierd how it all works out, but basically, the sensor signals to the computer that it's at __ temperature, and kicks on the low speed fan. If the sensor is no good, the sensor won't signal anything to the computer, and you will start to overheat. The high speed fan will kick on after a certain point though because the sensor will start to get extremely hot, and get the hint that the fan needs to be turned on. Niether fan speed will work if the sensor is just plain out bad.
post #7 of 10 Old 02-26-2003, 01:41 AM Thread Starter
95GTfiveOh,
So you are saying you had the low speed fan not work, then you ran the KOEO test and the low speed did work? Then you changed the ECT sensor and everything was fine? If so then that's my problem.
I have both low and high speed KOEO test, but with the car running, only the high speed fan works.
Pete
PH112 is offline
post #8 of 10 Old 02-26-2003, 09:19 PM
95GTfiveOh's Avatar
When I had the fan problem, I never thought of running the KOER test, until a couple of weeks later. For some reason, the fan seemed to work only during this process, and not when normally driving. I was very suprised how that little piece of crap sensor was the problem all along.
post #9 of 10 Old 02-27-2003, 01:41 AM
that's wierd cause when my fan didnt work at all, i changed my ect sensor (40 bucks) and i dont remember my low speed fan ever working.
06 Mazdaspeed6
5ptSlow is offline
post #10 of 10 Old 03-16-2003, 09:39 AM
slantman's Avatar
[QUOTE]Originally posted by 95GTfiveOh
[B]THe electronic coolant temperture sensor (ECT). It's right next the thermostat housing. Just unplug it, unscrew it out, put the new one, and you are set to go. The temperature sending unit is what controls your guage inside the car.
the ect does not run the gage
there are 2 sending units the one near the thermostat housing tell the computer the coolant temp
the one screwed in to the lower intake with one wire runs the gage.
this is what the computer sees in the stock program
ECT1_HS_FAN_ON 224 # ECT1 to turn on HS cooling Fan
ECT2_HS_FAN_ON 228 # ECT2 to turn on HS cooling Fan
ECT_HS_FAN_OFF 220 # ECT to turn off HS cooling Fan
ECT_LS_FAN_OFF 204 # ECT to turn off LS cooling Fan
ECT_LS_FAN_ON 208 # ECT to turn on LS cooling Fan
GT 40 long block gt 40x heads, B303 cam BBK 70MM TB, EDELBROCK PERFORMER RPM , MAC COLD AIR, KIRBAN ADJUSTABLE FPR , TWEECER RT.
FMS 30LB Injectors, PRO-M 75 MM Mass Air Sensor, MSD Pro Billet distributor, Msd Blaster coil, Crane HI-6S Igniton.
BBK 1 5/8 EQUAL LENGTH HEADERS, STAINLESS STEEL 2 1/2 H PIPE, Mangnaflow Polished SS 2 1/2 Cat Back, 3 1/2 Tips
via 1200mhz carputer, gps, mp3 ,dvd
1968 firebird 400
1996 sts 4.6 DOHV NORTHSTAR
slantman is offline
High Speed Fan Verification? WickedSnake00 GT & SOHC 4 09-07-2013 05:57 PM
Sputtering while driving shiz1125 5.0/5.8 Engine Tech 16 04-03-2012 04:14 PM
8.8 Clunk at low speed left turn and high speed coasts Floordford GT & SOHC 10 09-29-2011 05:10 PM
Low speed only works during KOER test. Help! 94_cobRa 94/95 Tech 7 08-25-2011 03:15 PM
HIGH SPEED FAN Prince95 Electrical & Wiring 3 06-06-2002 06:08 PM
