MSD-6AL - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 02-20-2003, 04:40 PM Thread Starter
MSD-6AL
just bought a new 6AL, i was told by the dude at jegs that i don't need a harness or adapter. My buddie put one in his 92 GT and used one. I havn't seen how the box hooks up so i don't know. Anyone have insight into this. Maybe some pics on how you hooked it up?
thanks
knoxville
JohnnyKnoxville is offline
post #2 of 9 Old 02-20-2003, 05:13 PM
Without the adapter harness I am pretty sure that you need to splice some wires together. I am not entirely sure though. Good Luck.
Mikes94GT is offline
post #3 of 9 Old 02-20-2003, 05:30 PM
JWALKER's Avatar
you will need to splice the msd coil wires to the stock coil wires.
If you dont want to do this, then better get the harness.
Jeff
95 GT
[email protected] 117.86
60' 1.79
tfs heads, st ht intake, 70mm TB, CAI, 30LB inj, 75 MAM, steeda #19 cam, Mac unequal shorties and X-pipe, FPR, 373 gears,
MSD ignition,tremec 3550, 125 Shot N2O.
Trying to tune with the Tweecer RT....
JWALKER is offline
post #4 of 9 Old 02-20-2003, 09:48 PM
Brian95GT's Avatar
The harness: approx. $20.00, 10 seconds to hook up, and keeps wires/area looking clean and neat.
Straight 6al wiring: free, approx. 30 min to 2 hours depending on handiness to hook up, and you have to keep the wires neat yourself.
I chose the harness. I got mine at mustangsunlimited.com because I live close to there and needed it quick. You can get it elsewhere. I highly suggest the harness.
1995 Rio Red GT 5-speed Coupe
2011 Black Edge AWD Limited
2003 Black Centennial GT Auto Convertible
Brian95GT is offline
post #5 of 9 Old 02-20-2003, 09:56 PM
You can cut and splice the wires but I think the plug and play harness is the way to go. If you pull the box for some reason you can just unplug it and plug it back in stock. It's worth the money IMO.
laidback is offline
post #6 of 9 Old 02-21-2003, 01:03 PM Thread Starter
thanks guys, i called jegs back and told them i did need a harness. I got a different salesman who seemed like he was up on things and got it right up for me....$13.99! Would still like to see where you guys mounted it in our crowded engine bay. I'm thinking about on the transmission hump on the passangers side if i can't find room....
knoxville
p.s. does this override the stock rev limiter? and do i take any stock components out to make this work?
post #7 of 9 Old 02-21-2003, 06:19 PM
Brian95GT's Avatar
I have no problems here!! Great deal---$13.99!!!
post #8 of 9 Old 02-21-2003, 06:24 PM
Brian95GT's Avatar
knoxville
I have the 6000rpm chip in now. Since the MSD rev limiter deals with spark, it will do that computerized thingy to keep the rpms from going higher than 6000--I forget what they say on the box and instuctions but it is something like a soft rev limiter. The stock one is set at 6250 I think. So, IMO it does override the stock computer. And no you just install and go. You do not have to do anything with the computer.
post #9 of 9 Old 02-21-2003, 07:27 PM
No it doesn't override the factory rev-limiter. If you put in the 6000 chip the box limit the revs but if you put the 6500 chip in the ECM will still limit the revs to 6250.
laidback is offline
For Sale MSD 6AL, MSD Blaster 3 coil, MSD 2step bluestang23 Electronics and Entertainment 5 04-21-2016 04:17 PM
For Sale MSD 6AL 6420 racin lsc Electronics and Entertainment 13 08-03-2014 11:52 AM
need help with MSD 6AL install....(LONG horror story inside). bolt-on-bandito General Mustang Tech 34 02-17-2014 06:59 PM
For Sale MSD 6AL and MSD BILLET DIST 250.00 vedali Electronics and Entertainment 4 08-20-2012 01:28 AM
For Sale MSD Billet EFI 302 Distributor, MSD 6AL, MSD 2 Step, MSD Window Switch, MSD TFI Coil Speeds8erM-1 Electronics and Entertainment 8 09-17-2011 05:04 PM
