Hey y’all I just picked up my dream fox that needs work. Furst order of business is fixing her cluster. The main concern is my fuel gauge. It stays at 7/8s no matter what. My tach moves consistently with her RPMs but it’s inaccurate (due to her cams) the speedometer is dead and doesn’t move. The gauges on the left seem to work but the oil pressure gauge sits at 1/8th. It’s been years since I’ve had a fox and I’m looking for some advice. Any help?
look to the oil press sender, short or open the sender, watch the gauge
disconnect the fuel sender at a easy connector and ohm the sender, is it ohm reading correct?
speedo, pull the gear from the trans and inspect, spin the cable with a drill, what happens?
Related Threads
Ford Mustang Forums
9.8M posts
200.7K members
Since 2001
