97 Cobra PATS Issue - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 04-22-2019, 12:49 PM Thread Starter
VenomousCobra's Avatar
97 Cobra PATS Issue
So car has been sitting for awhile, key fob has been problematic for years, but good batteries in it, but will no longer lock/unlock doors. and when I put the key in the ignition, the Anti-Theft light just flashes, and will not crank at all. I've done hours of searching on the net, tried many different processes to try to resolve my issue. Nothing so far has worked, I have an appointment for the dealer Friday to have them look at it, but would still like to solve it prior to towing it to the dealer. I have only 1 remote/1 key, so that might be more difficult for them to fix. The range on my remote has always been terrible, like <10 feet from the car to operate locks. But that still doesn't explain the key not being recognized by the car.
Thanks, in advance,
Jeff
97 Cobra. Bassani catted X-pipe , CDC Side exhaust kit, 4.10's, Upgraded 11" 26 spline FMS clutch T56 Magnum 6 speed. Forged Internals, JE 9cc Pistons, Vortech V-1 S-Trim 3.33" pulley, AFM PP SCT BA2400, 55lb/hr Inj. 501.71HP/415.4TQ on Mustang Dyno
Jeff
VenomousCobra is offline
post #2 of 8 Old 04-22-2019, 01:05 PM
key fob has nothing to do with PATS
the good news is that all 96-97 cobras have the exact same pats code in them so if u suspect the ecu is bad u can simply swap it with another and no programming is needed since the pats code is the same.
best bet is to plug in to the obdii port and see what it says
DIY Tuning -
TMoss Porting - tmoss.efidynotuning.com
Decipha is offline
post #3 of 8 Old 04-22-2019, 01:57 PM Thread Starter
Understood, just giving context. Tried connecting OBD scan tool to OBD II port, but disconnects right away multiple times when I key on, and connect. Not sure if that is because the Alarm is trying to go off, because I opened the door without disarming via remote or not.
Jeff
post #4 of 8 Old 04-22-2019, 02:35 PM
indy2000's Avatar
you should still be able to access pcm and anti theft module
i suspect you have a anti theft module issue, maybe comm failure
indy2000 is offline
post #5 of 8 Old 04-23-2019, 12:15 PM Thread Starter
So, I pulled and replaced a couple of connectors around the ECU, and it magically fixed itself. Started right up afterwards. Thanks for the help everyone.
post #6 of 8 Old 04-23-2019, 04:14 PM
indy2000's Avatar
Restored a poor connection, maybe?
Can that be trusted?
indy2000 is offline
post #7 of 8 Old 04-23-2019, 04:21 PM Thread Starter
That's what I'm thinking. Also found out that even though the remote batteries measure >3V, doesn't mean they will work in the remote. New batteries solved my remote problem also.
post #8 of 8 Old 04-24-2019, 09:08 AM
indy2000's Avatar
batteries can retain a surface charge that can show to be okay, put the battery under a load, voltage can drop quickly
indy2000 is offline
For Sale 96 Cobra Part Out bmwm3 Exterior Parts 25 09-03-2012 12:21 AM
For Sale 96 Cobra Parts bmwm3 Modular Engine Parts 18 03-26-2012 03:57 PM
99 cobra clutch issue. need help ASAP!! killab18 SVT & DOHC 3 01-11-2012 02:28 AM
Top 50 Quickest Lists Black_Bullit GT & SOHC 11 02-09-2005 01:13 PM
