1999 Mustang Electrical issue/failure - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 04-16-2019, 04:13 PM Thread Starter
Hey I am new to the forum. I recently purchased this 99 Mustang (65K original miles) and it has been running pretty good until I swapped out the headlights. The previous owner had led's and the lenses were all crapped up, so I replaced them with the Halo-LED with the standard bulb. I am not sure if this is what is causing the issue but while driving the fuel cut off at idle and I thought it was a fuel pump. Mechanic said Fuel pump was fine.
Two days later I get in the car, completely dead. I jump start it and drive a couple of miles and I lose fuel to the engine again. Luckily it started again but a few miles later ALL power shut down while driving. No hazards, nothing! I jiggled the positive terminal and it started again. Definitely an electrical issue, not sure if the new bulbs are causing a draw issue with some kind of relay (I am not an electric guy).
Has anybody ever experienced this? Also could a dead battery in the key fob cause this (causing the factory alarm to engage)? I brought the car back to the shop and then realized this and put fresh batteries in the fob and left it with him. I would really hope this is the issue, but I would rather explore every option than get stuck in the middle of a highway again.
Thanks! Any helpful replies would be great.
SilverSurfer99 is offline
post #2 of 2 Old 04-17-2019, 02:09 PM
indy2000's Avatar
You have an intermittent open in the car
Unless you can reproduce it, will be fun to find
indy2000 is offline
Misc. Parts myersmij79 Modular Engine Parts 12 12-21-2009 04:35 AM
Fox body parts for sale gt or lx 79-86 87-93 Mustang20 Miscellaneous Mustang Parts 33 08-19-2006 10:30 PM
Mach 1 Press Release frank3si GT & SOHC 0 03-27-2002 10:20 AM
