1992 GT airbag code 23 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 01-26-2019, 11:38 PM Thread Starter
Getting a airbag code 23. Any suggestions where to look for "open connection in safing sensor feed curcuit"
Guy
gmorris is offline
post #2 of 14 Old 01-27-2019, 10:03 AM
indy2000's Avatar
most likely in the clockspring
you could check that part of the circuit first
indy2000 is offline
post #3 of 14 Old 01-27-2019, 07:00 PM Thread Starter
Horn, etc works. Any way to check that circuit? It does not appear that a new one is available. $100 used on eBay
Guy
gmorris is offline
post #4 of 14 Old 01-27-2019, 07:19 PM
indy2000's Avatar
ofcourse
remove power and ohm the circuit as the module sees it
or
remove the airbag from the equation, and supply correct ohm resistors to imitate a working air bag, and see if the code persists..........
indy2000 is offline
post #5 of 14 Old 02-06-2019, 12:47 AM Thread Starter
Just to let you know that I didn't just ask and run...........i ordered a clockspring on EBay and the package was stolen along with two other packages that were delivered last Thursday. POS people........anyhow, got another one coming and I'll pull the steering wheel and do as you suggest. I have one of those ohm sticks for testing the airbag circuit.
Guy
gmorris is offline
post #6 of 14 Old 02-09-2019, 01:19 PM Thread Starter
Tested the circuit. No good. Replaced the clockspring. Still same code 23. I assume a broken wire someplace. Any known weak spots?
Guy
gmorris is offline
post #7 of 14 Old 02-09-2019, 04:51 PM
indy2000's Avatar
results of the test?
the entire circuit is a weak point
why did you not isolate the circuit at connectors to find the open?
you may not needed to replace the clockspring, by testing
indy2000 is offline
post #8 of 14 Old 02-10-2019, 02:24 AM Thread Starter
Indy, sorry, but I know very little about how to test the circuit. Electrical is my weak point. I removed the airbag and I have one if those diagnostic plugs that has the correct resistance to simulate the air bag. No change in the error code. Did the same thing after replacing the clockspring. So you are correct, I do not think the airbag or clockspring were bad. Beyond that, what you are suggesting is greek to me. I don't know what "isolate the circuit at the connectors " physically means
Guy
gmorris is offline
post #9 of 14 Old 02-10-2019, 10:39 AM
indy2000's Avatar
Do you want to learn Greek?
indy2000 is offline
post #10 of 14 Old 02-10-2019, 02:46 PM Thread Starter
Yes please. I own a VOM and I can turn it on i use it checking voltages, continuety, and occasionally as an ohm meter if i`m following instructions. This car is assembled so I'm afraid that the next step may involve tearing the interior apart again. Some brief history that may help
The first code I had was a 22. I replaced the sensor in the B pillar with a brand new Ford sensor (that was the only Safing sensor I could find in the manuals). No change. Then I replaced the control module. That got rid of the 22 and now I have the 23 code. My understanding of the system logic is that it displays one error code at a time starting with the worst one. For all I know, there could be additional codes after this one. The module came out of a '92 that did not have any codes (also where I got the clockspring) so i think the parts are good but untested (I have no idea how to test them)
This car is all original and the remaining sensors are all in place and all connected. No wires are tapped into, etc.
gmorris is offline
post #11 of 14 Old 02-10-2019, 05:06 PM
indy2000's Avatar
are you able to id the locations of all the connections in the circuit
do you have a piercing tools, and T test backprobing test pins?
we can access the easiest connections first and move from there
i have 92 EVTM with nice diagrams, i can scan and send to you and we can go through it step by step
I will not spoon feed you,i will ask you what you think we should see before we test, so when we test, we can conclusively id the issue
indy2000 is offline
post #12 of 14 Old 02-10-2019, 05:30 PM Thread Starter
The diagrams would certainly help. I have the wiring and vacuum manual but no airbag info in it. I can find all the connectors for the parts i'm aware of so the diagram should help me figure out where they all are. I am assuming you mean the physical connection plugs. Beyond that, like ground connections, I have no idea. Thanks for the offer.
Your other tool list: I don't have anything official. I have some pins and needles. I'll look on EBay for the test pins
Thanks again, Guy
gmorris is offline
post #13 of 14 Old 02-10-2019, 06:53 PM
indy2000's Avatar
pm me where to send the pics
indy2000 is offline
post #14 of 14 Old 02-26-2019, 12:54 AM Thread Starter
Just wanted to close out this thread. Indy2000 was great. Sent me the wiring diagrams and advise. I started looking for a wiring issue. Fortunately, it was an easy search. One of the wires was broken at the rear crash sensor connector. Fixed the connector and airbag light is off.
Guy
gmorris is offline
Misc. Parts myersmij79 Electronics and Entertainment 9 03-25-2010 10:36 AM
Misc. Parts myersmij79 Miscellaneous Mustang Parts 8 09-03-2009 02:42 PM
Misc. Parts myersmij79 Suspension 8 09-03-2009 02:26 PM
Misc. Parts myersmij79 Drivetrain Parts 8 09-03-2009 02:25 PM
1990 GT VERT: 1ST IMPRESSIONS IJCOBRA General Mustang Tech 34 05-04-2004 12:35 AM
