1993 mustang electrical nightmare - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By 6v89stgn
post #1 of 12 Old 11-16-2018, 01:53 PM Thread Starter
Ok guys im going to try and explain this as best as I can my 1993 mustang gt is acting crazy!!
So for the past week or so ive had a few electrical issues nothing I was to worried about. A few examples are my dome light went out. My headlights flashed once and about a month ago my headlights went out all together for a min while driving. Well I decided to drive home to Nashville for the holidays and was installing a new head unit and I couldn’t get it working. Tested to wiring with two separate multi meters and got zero volts from the stereo siring harness. So, I then turn the car all the way on and took both my multi meters and tested the back of every fuse in the panel and got zero volts from all of them (weird….) so I then pulled every fuse and they all were fine. how is that possible with most all the accessories the power were just fine? I then turned my car off changed my oil then tried again first testing the fuses on the back side again all but one had volts this time fuse #6 so I pulled it but this time it was fried. I replaced it decided to go for a drive and on that drive my door chime came on wont go off. My dome light came on and now won’t go off. My head lights flashed, and my dash lights flickered on off several times and the needles were jumping all over the place. I come home park it and this morning the damn door chime and dome light are still on. What do I do?? I was supposed to leave for home today. Also side note I believe my heater core is messed up to because I also smell strong antifreeze in the car and ive had to put about 3 gallons of anti-freeze in her over the last week-two weeks could this be related?
moon9398 is offline
post #2 of 12 Old 11-16-2018, 02:19 PM
Blown88GT's Avatar
You're not going to fix these problems in 1 day. Park it & rent a car. Or would you like to get stranded in the snow & cold & die?
1988 GT, 57k mi, Orig Owner
Blown88GT is offline
post #3 of 12 Old 11-16-2018, 03:24 PM Thread Starter
I've already decided to stay home and I can't afford to rent a car any idea what could be wrong with it would be greatly appreciated if I can get her back on the road
moon9398 is offline
post #4 of 12 Old 11-16-2018, 03:58 PM
indy2000's Avatar
Do you have a evtm for your car?
You are going to need to know the power and ground locations
I can tell you how test, once you know where to test
indy2000 is offline
post #5 of 12 Old 11-16-2018, 10:14 PM
Park it and beg, borrow, rent another car. With it using that much coolant, it's not reliable enough for any long distances, anything more than a mile or so.
These cars are getting old, they aren't what they used to be. They're more novelty now than daily driver UNLESS you like working on them a lot or you pay someone to properly completely restore it to OE specifications using OE parts-which costs a ton.
I think you have several different problems, but I'm not the one to help you find/fix them because I'm not on this site often.
'92GT, 427" and '93 "LXVO" coupe
toddturbo is offline
post #6 of 12 Old 11-16-2018, 10:58 PM
thadude's Avatar
He means the Electrical and Vacuum Troubleshooting manual which part of can be found here
Fuel Injection Technical Library » Mustang EVTM?s
Good luck and I'd listen to indy2000, he'll help ya out
1993 Cobra #1282
thadude is offline
post #7 of 12 Old 11-17-2018, 09:58 AM
TomR's Avatar
It almost sounds like you don't have a ground to the chassis from the battery negative post for the electrical part.
TomR is offline
post #8 of 12 Old 11-21-2018, 07:45 PM
6v89stgn's Avatar
Check the main passenger compartment harness. It leads from the fuse block inside to driver side kick panel then along the rocker panel just under the carpet. It's not protected and can get pinched where it runs over raised portions of the floor pan. Mine shorted out on my 89 and almost burned my whole car up. I caught in time and only had to resplice over 100 wire leads and replace the carpet. Late model resto now offers a replacement cabin harness but its a bit pricey, I think about 800 dollars.
6v89stgn is offline
post #9 of 12 Old 11-22-2018, 02:14 AM
Maybe take a look at the ignition switch. They are notorious for falling apart. When they separate, all kinds of funky things happen. Intermittent problems of all sorts. Hope you get it lined out.
90gt92lx95svt is offline
post #10 of 12 Old 11-22-2018, 01:01 PM
thadude's Avatar
“Only” lol
1993 Cobra #1282
thadude is offline
post #11 of 12 Old 11-22-2018, 02:54 PM
6v89stgn's Avatar
The shop manual really came in handy that time
thadude likes this.
6v89stgn is offline
post #12 of 12 Old 11-26-2018, 12:37 AM
90trunk's Avatar
Minor Hijack: Thanks for posting the link to fuelinjectedford.com, as I had not visited there before. What a great reference point for Ford EEC information!
Regards,
Craig
[email protected] at Milan,3450#...
Dynojet'd 286rwhp/331rwtq Stock Cam, GT40 Irons
90trunk is offline
For Sale 1993 Mustang LX Coupe Reef Blue Dogman_1969 Mustangs For Sale/Wanted, 1987-1993 5 08-07-2017 03:10 PM
For Sale LARGE Lot of NOS and USED 5.0 93 - 87 Mustang Cobra parts mach3514v Exterior Parts 0 06-23-2011 08:45 PM
