88 5.0 won't start - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 08-23-2018, 09:02 PM Thread Starter
88 5.0 won't start
Having a no start issue with my 88 5.0. I put the key in and I get the normal "door open key in ignition" tone dome light on everything normal. Turn the key to accessory and everything still normal. As soon as I turn past accessory into "run" I loose almost all power. Door tone stops, dome light out, gauges dead. Only a slight noise from the back that sound like my fuel pump but weak. I have clean terminals and a good battery. I have already replaced the ignition switch also. I am not an electrician. This issues happened suddenly and without warning. Been a clean good running car for years.
Hot88 is offline
post #2 of 6 Old 08-23-2018, 09:19 PM
Trader Feedback: (21)
That sounds like a poor ground somewhere.
For everything that is worthwhile, there is a counterfeit.
boostup89 is online now
post #3 of 6 Old 08-23-2018, 10:30 PM
indy2000's Avatar
why did you replace the switch?
indy2000 is offline
post #4 of 6 Old 08-24-2018, 08:38 AM Thread Starter
As I said the car does not start. I have very limited diagnostic ability but I knew the ignition switch is a common problem in these cars and I thought it could have been causing those symptoms therefor replaced.
Hot88 is offline
post #5 of 6 Old 08-24-2018, 07:35 PM
indy2000's Avatar
cause it doesn't start, does not mean you cannot test the switch
use a test light to batt neg
and probe across the switch in the various positions, the light will come on when the switch is working
you only need to know which pins to test at each position
they sell wiring diagrams, sometimes for free, so that you can id them
infact you don't need them, if you understand the design....regardless, its easy to test
so lets assume your NEW switch is faulty
test it.
indy2000 is offline
post #6 of 6 Old 08-25-2018, 05:13 PM
Blown88GT's Avatar
If you replaced the ignition switch, you are an electrician, of sorts.
Your good running car is 30 years old.
Maybe battery terminals are clean, but cable clamps not tight enough.
1988 GT, 57k mi, Orig Owner
Blown88GT is offline
Car Rarity? preppypyro General Mustang Tech 8 04-13-2016 01:14 PM
code 66 and 98 but i have no Maf keyl0ger General Mustang Tech 15 05-07-2014 07:58 PM
88 5.0 Mark VII LSC Cranks wont start White88LSC 5.0/5.8 Engine Tech 11 09-12-2013 02:37 PM
5.0 as a donor motor... start with Explorer or Mustang? taiden 5.0/5.8 Engine Tech 5 05-22-2011 07:26 PM
5.0 Mustang vs LS2 Vette vs LS3 Vette 00whiteGTvert S-197 Mustang GT (2011-2014) 41 01-21-2011 09:08 AM
