MSD 6al wonít start 1994 gt - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 08-08-2018, 10:03 PM Thread Starter
drhoward's Avatar
So I have a msd 6al mounted in my trunk, iíve had it running quite a few times before I installed my super charger and after with no issues, but all of a sudden the car wonít start. Iíve bypassed it and started it on the stock ignition and it fired right up. Iíve also replaced the harness connector to the coil (with one I had laying around from a previous setup) since the one I had on there was looking a bit weathered, still didnít help. Iíve checked the main power heavy red wire and itís got power in the trunk. Iíve also checked the small red and orange wire in the engine bay and the trunk with the ignition on, they both show power.
Is there anything else I should be checking or is my box just bad? Itís not a big deal to replace it, I just hate to spend the money if I donít have to. Like I said itís mounted in my trunk so is there anything else that could be shorting out? Any help would be appreciated.
94 mustang GT... Ported Mustang upper and lower, msd ignition, ford racing u/d pullies, ebelbrock tb, ford racing 3.73's, 75 NOS dry kit
1990 Eagle Talon TSi AWD
drhoward is offline
post #2 of 12 Old 08-08-2018, 10:40 PM
indy2000's Avatar
to make spark you need a ground
is the box providing a switching ground, so fast that you need a scope to see it??
indy2000 is offline
post #3 of 12 Old 08-08-2018, 10:47 PM Thread Starter
drhoward's Avatar
I donít know what you mean? The negative wire is connected directly to the negative battery terminal. Is there a way to check it?
drhoward is offline
post #4 of 12 Old 08-08-2018, 11:11 PM
indy2000's Avatar
what?
do you know how spark is made?
indy2000 is offline
post #5 of 12 Old 08-08-2018, 11:14 PM Thread Starter
drhoward's Avatar
I donít know what you mean by I need a scope to see the switched ground?
drhoward is offline
post #6 of 12 Old 08-09-2018, 12:18 AM
indy2000's Avatar
tell me how spark is made
indy2000 is offline
post #7 of 12 Old 08-09-2018, 09:04 AM Thread Starter
drhoward's Avatar
Thanks for your informative answer. Does anyone else have any suggestions of what I can check?
drhoward is offline
post #8 of 12 Old 08-09-2018, 09:53 AM
indy2000's Avatar
do you know how spark is made, yes or no?
the type of test is predicated on that, as you obviously dont seem to understand what i am suggesting
your comment of having the negative wire go to battery negative post seems a little obvious no?
have you grounded coil neg rapidly to see if spark can be made?
indy2000 is offline
post #9 of 12 Old 08-09-2018, 10:07 PM
Pretty typical with his responses. I had this same issue a few years ago and just swapped it out for a new unit and worked fine.
94 Cobra
363 Stroker with S-Trim coming 2019;-)
stacked8 is offline
post #10 of 12 Old 08-09-2018, 10:30 PM
ashleyroachclip's Avatar
While Indy may seem a bit harsh , he is trying to teach you how to properly determine what is wrong , and properly trouble shoot the problem .
You must know how a component works , before you can diagnose the component .
Once you have that knowledge, you can properly determine if In fact that component is the problem , or the supporting system .
Notice i said PROPERLY SEVERAL TIMES , for a reason .
Clowns to the left of me , jokers to the right ......
ashleyroachclip is offline
post #11 of 12 Old 08-10-2018, 12:05 AM
indy2000's Avatar
if that is your extent of tech support, swap parts, then so be it, no harm
no one will judge you any less.....
indy2000 is offline
post #12 of 12 Old 08-10-2018, 09:15 AM Thread Starter
drhoward's Avatar
I'm pretty sure it's a bad ground somewhere, I just need to pull everything apart and try to find where. It's just a bitch to do on my car since I have everything tucked away under the car. I guess it gives me an excuse to drink in my garage this weekend.
drhoward is offline
1993 GT no start gremlins JCBeaver General Mustang Tech 13 02-25-2017 10:41 PM
1994 GT Cold Start / Braking / Steering Stall DonGonzo 94/95 Tech 11 01-04-2014 11:29 PM
For Sale New MSD 6AL, Window switch, coil. SVTCobra347 Electronics and Entertainment 0 01-26-2011 12:02 AM
For Sale Like new MSD 6AL & MSD 2-step 94_cobRa Electronics and Entertainment 1 11-24-2010 01:12 PM
